what gauge wire do you use to wire your panels?
Page 1 of 1 [9 Posts]
sndbyte
PostPosted: Sat Jul 10, 2010 11:51 am    Post subject: what gauge wire do you use to wire your panels? Reply with quote  Mark this post and the followings unread
Hi everyone,
I was wondering what gauge wire people use to wire up their synth panels? In the past I have used 22 AWG stranded wire. But I was thinking a thinner wire would be easier to work with (such as 24 AWG stranded).
Is 24 AWG wire too thin for DIY synths? Or will it work just as well as 22 AWG?
thanks in advance,
Chris
numbertalk
PostPosted: Sat Jul 10, 2010 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I use 24AWG.
Rykhaard
PostPosted: Sat Jul 10, 2010 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Until early last year I had been using 24 guage stranded since the mid or earlier 90's.
Early last year though I got a LOT of 8 conductor 26 guage TEFLON cable! It's been working fine, as long as the runs are short.
The 24 is MUCH nicer to work with. The original spools that I had bought in the early 90's were 20g and 22g. I ended up using the 20g for power, later and finally moved to 24g, with 22g for my power runs.
sndbyte
PostPosted: Sat Jul 10, 2010 11:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I decided to order a few rolls of 24 gauge tonight. I'm going to use it on the Soundlab I'm working on.
thanks
zthee
PostPosted: Fri Jul 16, 2010 12:05 am    Post subject: Reply with quote  Mark this post and the followings unread
24 for panel wiring and 20 for PSU wiring.
LektroiD
PostPosted: Tue Jul 20, 2010 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
This is what I use (7/0.2mm). No mention of the sizes anyone's mentioned in this thread though. Not sure how you guys are measuring it? 24 AWG = 24mm? That would be mighty thick, unless that's the equivalent to 0.24mm, perhaps? Please explain?
http://www.rapidonline.com/sku/Cables-Connectors/Equipment-Wire/Equipment-Wire/7-0.2mm-Equipment-wire-%28plain-colours%29/62320/01-0480
LektroiD
emdot_ambient
PostPosted: Tue Jul 20, 2010 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
LektroiD wrote:
24 AWG = 24mm?
Nope. See here http://www.engineeringtoolbox.com/awg-wire-gauge-d_731.html
AWG = American Wire Gauge
24 AWG is .51 mm or .2 mm squared (cross sectional area)
Smaller AWG is actually bigger wire.
Why? Because we're Americans and can get away with it. Wink
LektroiD
PostPosted: Tue Jul 20, 2010 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
there must be something that explains the difference betweem 7/0.2 and 24AWG (or whatever its equivalent is)? This whole wire thing has just got a whole lot more confusing
LektroiD
Audio files: 161
PostPosted: Tue Jul 20, 2010 4:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Rich .
I use 7 strand/0.2mm (7/0.2) and sometimes 16/0.2 for the short runs to the panel pots & switches etc..
I also use 0.5 mm2 3core electrical table lamp flex for the busbar to pcb power cables , then 1.5mm2 electrical flex from power supply board to the busbars.
Here's a pic of one of 5 busbars in my blue beast.
 Filesize:  311.76 KB
 Viewed:  183 Time(s)
