Clavia Nord Lead 2X problem
Page 1 of 1 [2 Posts]
PostPosted: Fri Feb 04, 2011 12:41 pm    Post subject:  Clavia Nord Lead 2X problem Reply with quote  Mark this post and the followings unread
Hello everyone.
Sorry for my bad English first of all.
I have this problem:
When I use my Nord Lead 2X after 10, 20 seconds, maybe 5 minutes this device goes to restart and write on the screen zeroes and ones. Midi is off, audio mono/unison (2.Ab - mono, doesn't change this problem). When i turn on the device on the screen: 1.00 (i think it is firmware version), then "nL2" - it is name, and then device is working. Maybe i can update this firmware version? What i need to do?
with/without MIDI - problem is.
with other power supply - problem is.
all cables are ok.
if i can change firmware what i need to do for this?
Thank you.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Feb 05, 2011 12:24 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome 6722619
It looks like a bad power supply.
First thing to do is open the red hood, see also
http://nm-archives.electro-music.com/020_NordLead2/Red_Lady/Index_bestanden/Red_Lady/115-230_vica_versa.htm
to see how to do this.
Check all cables by disconnecting-connecting the plugs.
No results?
Go to the nearby service centre.
Check also this thread
http://electro-music.com/forum/topic-31679.html
Wout
