need help undertanding AVR /ARDUINO timers and interrupts!
Page 1 of 1 [2 Posts]
loss1234
PostPosted: Thu Feb 10, 2011 11:50 am    Post subject: need help undertanding AVR /ARDUINO timers and interrupts! Reply with quote  Mark this post and the followings unread
hello there
I have been working with Arduino for a couple weeks now
I can get it to do some simple things but much is still a mystery
I am trying to make a program that reads from an ANALOG INPUT for let's say ONE second and dumps what it reads into an ARRAY.
the problem is this
though I know how to read from the analog pins, put the data from them into a function called VAL, I do not know how to do any such thing in regards to TIME...and since an array would fill up far too quickly if done all at once, I thought that maybe the array could read what is on the PIN every second or every-time some kind of event took place ( an overflow?)
but this would take me understanding how to use the clock, the timer, the interrupts?etc
so....where to start? any advice? hints, etc?
i get the feeling that to do anything powerful with an Arduino/PIC you have to understand arrays and timers....
thanks so much
Skellz
PostPosted: Mon Feb 14, 2011 5:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1261124850 Arduino forum post
http://www.uchobby.com/ Very in depth tutorial, site is down at the moment
http://interface.khm.de/forums.html/lab/experiments/arduino-realtime-audio-processing/
ProtoStack Tutorials
http://www.protostack.com/blog/2010/06/introduction-to-io-registers/
http://www.protostack.com/blog/2010/09/timer-interrupts-on-an-atmega168/#more-235
http://www.protostack.com/blog/2010/09/external-interrupts-on-an-atmega168/#more-209
Ok here is a probably inaccurate explanation as i only just started my self.
The arduino has 3 timers and each timer has several settings that have to be set up for the task at hand. Timers can be set up to trigger special sections of code called interrupt service routines. When the trigger happens arduino stops what it is doing and runs through the interrupt service routine then returns to where it was in the program when the trigger happened.
So if you wanted to sample audio you would set up your timer to trigger an interrupt service routine at audio rate, eg 8khz and place an analogRead() in the service routine, if you wanted to play back audio you would place an analogWrite() or place code that would send the audio to a dac in the interrupt service routine.
Now here is the easy part
The settings for the timers are held in special registers. Each register has 8 bits and usually each bit is a setting for the timer. So you have to change the state of each bit individually, in C you can use the bitwise operators to manipulate individual bits http://en.wikipedia.org/wiki/Bitwise_operation
And just to add to the confusion, there are avr specific commands for manipulating register bits.
Im pretty sure cbi means clear bit and sbi means set bit
sbi(ADMUX,REFS0);
cbi(ADMUX,REFS1);
Also check out the data sheet from atmel it has a description of the registers. The uchobby link also has a very detailed description of the registers your interested in.
