VCO trimming + VCO as an LFO?
Page 1 of 1 [3 Posts]
kupfer_m
PostPosted: Mon Jun 27, 2011 6:34 am    Post subject: VCO trimming + VCO as an LFO? Reply with quote  Mark this post and the followings unread
When trimming my Yusynth VCO (BC547 version) I could not get a correct
V/OCT trim. Trimmer T2 reached the end of its range before getting the correct V/OCT step. I found that lowering the 33k resistor in series with T2 to 22k did the job for me. The VCO now tracks correct!
Just want to share my findings.
Another question: when trying to trim I noticed that the VCO could produce very low frequencies. What adjustment could be made to turn the VCO into a VC-LFO?
Thanks,
Jim
yusynth
PostPosted: Wed Jun 29, 2011 4:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you using BC547B as indicated ? Were R3,R4,R5 and R11 1% tolerance ?
You can turn it to a LFO by changing the value of C8 (making it 2.2n but the V/Oct tracking might not be as good)
Yves
kupfer_m
PostPosted: Wed Jun 29, 2011 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I did! But the VCO tracks now at 1V/Oct so I'm happy!
