CGS65 mode switched?
Page 1 of 1 [3 Posts]
rosch
PostPosted: Thu Jul 21, 2011 12:35 am    Post subject: CGS65 mode switched? Reply with quote  Mark this post and the followings unread
hi!
i'm building the tube VCA/ timbral gate. i'd like, if possible, to make the mode of operation switchable.
since both options for the resistor (330K) and for the bridges have one common contact, i'd like to try switching them with a DP ON-ON switch.
question is: is there a reason not to do it? i mean, is there something i have to watch, like using a special switch to make sure one contact opens before the other can close, in order to avoid a short?
anybody tried that?
andrewF
PostPosted: Thu Jul 21, 2011 2:28 am    Post subject: Reply with quote  Mark this post and the followings unread
you could use an on/off/on switch, to ensure the 1st connection is broken before the next is made.
rosch
PostPosted: Thu Jul 21, 2011 3:57 am    Post subject: Reply with quote  Mark this post and the followings unread
good idea, thanks! i'll do it that way.
