Steiner VCF All IN?
Page 1 of 1 [3 Posts]
roman_f
PostPosted: Sun Oct 16, 2011 6:51 pm    Post subject: Steiner VCF All IN? Reply with quote  Mark this post and the followings unread
did anyone manage now to do the "all in" option for CGS35?
i've tried to use switching jacks, but it does not work as soon as it's connecting all the inputs together all the time
did i do anything wrong?
sneakthief
PostPosted: Mon Oct 17, 2011 3:58 am    Post subject: Reply with quote  Mark this post and the followings unread
You're doing it wrong. Check for a short-circuit somewhere.
The tip of the jack that plugs into the all-pass input should be connected to every single switched input of the LP/HP/BP inputs.
So if a jack is plugged into the LP, HP or BP, the normalization from the all-pass input is broken.
Sneak-Thief - raw electrofunk
roman_f
PostPosted: Mon Oct 17, 2011 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
wired again, now all's prefect
thanks)
