3phase
G2 patch files: 141
Posted: Sun Feb 27, 2005 1:57 pm Post subject:
How to emulate the NM1 FMA input behaviour ??? |
I wasnt able to get the same exponential behaviour on the G2 lin FM inputs..regardless what i tried.. i had to give up...
Somebody else knows how to do it ? |
ik
Joined: Jan 30, 2005 Posts: 50 Location: North Carolina
G2 patch files: 25
Joined: Apr 03, 2004 Posts: 24434 Location: The Netherlands, Enschede
Audio files: 297
Posted: Mon Feb 28, 2005 3:28 am Post subject:
To my knowledge the FMA input is a linear input with twice the sensitivity of the gray input.
Jan. |
3phase
G2 patch files: 141
Posted: Mon Feb 28, 2005 4:52 am Post subject:
Thanks.. i will try it...
and twice the sensetivity of the grey input ???  |
Audio files: 297
Posted: Mon Feb 28, 2005 6:52 am Post subject:
3phase wrote: | Thanks.. i will try it...
and twice the sensetivity of the grey input ??? :-) |
I was refering to the Classic's module, not to the G2 ...
Jan. |
3phase
G2 patch files: 141
Posted: Mon Feb 28, 2005 9:07 am Post subject:
I know...but i still have the problem to interpretate 2 as sensetiv...because all the inputs are scale from 0-127...are talking about the exponential curve? |
Audio files: 297
Posted: Mon Feb 28, 2005 9:58 am Post subject:
Now you got me confused ... I was recalling some dusty knowledge from my head .. let me try to undust.
From page 35 of the Classic manual :
FREQUENCY MODULATION (FM)
A signal routed to an FM input on a module affects the pitch by modulating it linearly in the frequency scale (see figure below).
[the figure refuses to be pasted here]
Twice as sensitive ... ah right, you were refering to the knob characteristic probably - the knob has an exponential curve (type II, explained on page 31 of the manual).
And I meant that where the grey input gives a certain frequency deviation (absolute, in Hz) for a certain input value the FMA input will give twice that deviation when the attenuator knob is turned fully open / clock wise.
The grey inputs are linear FM inputs as well - although the manual doesnt tell you so.
(The manual I used is http://www.clavia.se/nordmodular/Files/NM3_0Ed2Manual.pdf )
Jan. |
Rob
Joined: Mar 29, 2004 Posts: 580 Location: The Hague/Netherlands/EC
G2 patch files: 109
Posted: Tue Mar 01, 2005 5:44 am Post subject:
3phase wrote: | I know...but i still have the problem to interpretate 2 as sensetiv...because all the inputs are scale from 0-127...are talking about the exponential curve? |
The exp/dB curve on the G2 is different to the exp curve of the NM1. (Note: the G2 exp and dB curve are the same)
This exp curve is always a compromise, as it should allow for both very shallow modulation (lower half of the knob range) and for mixing of audio levels (higher half of the knob range). The NM1 exp curve had too little resolution to conveniently mix audio levels, so the curve got balanced better. It is definitely more versatile now.
Keep in mind that backwards compatibility has not been one of the design specifications. So, it does not pay to try to get things exactly like on the NM1, many times that won't work. |
3phase
G2 patch files: 141
Posted: Tue Mar 08, 2005 7:35 am Post subject:
i was wrong...solved it |
