Old versions of the Nord Modular Editor
Page 1 of 1 [3 Posts]
wouter
PostPosted: Sat May 16, 2015 2:43 pm    Post subject: Old versions of the Nord Modular Editor Reply with quote  Mark this post and the followings unread
Does someone has old versions (< v3) of the Nord Modular editor? I want to add it to my music software museum Smile
www.granucon.com
varice
Audio files: 29
G2 patch files: 54
PostPosted: Sun May 17, 2015 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here you go wouter Exclamation This is a copy of the original installer for the 2.10 Editor version for Windows. I had to rename the filename extension from .exe to .zip since the forum does not allow .exe, so you will need to restore it to .exe to run the installer.
NM2_10b.zip
Nord Modular 2.10 Editor Installer (rename .zip to .exe)
 Filename:  NM2_10b.zip
 Filesize:  1.77 MB
 Downloaded:  475 Time(s)
varice
wouter
PostPosted: Mon May 18, 2015 11:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Smile
 Filesize:  145.28 KB
 Viewed:  412 Time(s)
www.granucon.com
