today> Twyndyllings LIve Chez Mosc
STMF7 Disco Board
BobTheDog
PostPosted: Fri Aug 14, 2015 12:02 pm    Post subject: STMF7 Disco Board Reply with quote  Mark this post and the followings unread
Just picked one of these up: http://www.st.com/st-web-ui/static/active/en/resource/technical/document/data_brief/DM00179227.pdf
ARM M7 with 4 point multi capacitive screen, fs & hs usb connectors, SAI with line in, line out and stereo outputs, SPDIF in and ethernet, cheap as chips. Only problem is that it uses Arduino headers so lots of GPIO is missing.
Managed to get it going as a 2 channel USB Audio device so far, looking at getting is running as a USB Midi device at the moment.
For the cost an amazing little board.
