Access Virus: erase bank C-D by A or B?
unclou
PostPosted: Sat Aug 22, 2015 1:14 pm    Post subject: Access Virus: erase bank C-D by A or B?
Subject description: Access Virus erase ROM banks
Hi everyone,
I have a Virus Classic same as Virus B.
There is an option in this synth were you can erase Flash/ROM bank (C-D) by your own RAM bank A or B.
This is very interesting since it would freed bank A or B to make new sounds and get rid of the factory sounds (C-D).
Of course i always have a backup of my sounds.
But in the manual, it is written that this operation is at your own risk (see below).
I wonder if any of you have tried it and if it worked well (?)
Here what is written is the manual + thanks in advance for your advice.
Store To Flash
This function allows you to write your favourite patches into the patch ROM of the Virus. The actualprocess is similar to that used to update the operating system. For technical reasons, only complete
banks can be written.
The Store To Flash function can be found here: SYSTEM>STORE TO FLASH
A>C, A>D, B>C, B>D, indicate which RAM bank will be written into which segment of the Virus patch ROM. A>C means, for instance, that the RAM
bank A will be written to ROM bank C. Hit the [STORE] button and confirm the safety alert message
WARNING: Despite the fact that the manufacturer of the FLASH ROMs guarantee thousands of write cycles, we recommend you use this function wisely. We took every technically possible precaution to ensure that even a power failure during the process of writing won't affect the operating system of the Virus. In the unlikely case of permanent damage to the FLASHROM, the FLASH ROM has to be exchanged by an authorised Access dealer or serivice facility.
This is not covered by the standard warranty.
