today> Twyndyllyngs Chez Mosc
Old capacitors as art?
Page 1 of 1 [4 Posts]
audiodef
Audio files: 63
PostPosted: Tue Nov 10, 2015 9:43 am    Post subject: Old capacitors as art? Reply with quote  Mark this post and the followings unread
I had one of my mixers repaired recently. The capacitors in the power supply were replaced. The shop gave me all the old caps in a bag. I have no use for them, but my partner immediately wanted them to make art with. Would that be safe? They are small caps, but I want to make sure they aren't going to accidentally discharge on her or any customers who buys her art made with these. The caps are 25V, 450 uF, and I'm guessing CD287 is a part number of some kind. I know there are some experienced electrical DIYers here, so any advice on this would be appreciated.
Audiodef.com
Soundcloud
Airlock
Audio files: 53
PostPosted: Wed Nov 11, 2015 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Short 'em out on something should take care of it.
audiodef
Audio files: 63
PostPosted: Wed Nov 11, 2015 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hm... I think I'm going to recycle them, just to be safe. Smile
Audiodef.com
Soundcloud
DES
PostPosted: Sun Nov 15, 2015 9:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Shouldn't be a problem untill you get to higher voltage caps. Still, a quick shorting with tin foil, pliers, etc. should work fine. Now if your partner comes across older high voltage oil filled caps...as cool as they look he'll want to stay away from them because some do have carcinogens - pretty nasty stuff if they leak...
www.davesneed.com
