 Forum index » Online Music
Three Miniatures for Electric Guitar
Page 1 of 1 [6 Posts]
Paul Wegmann
PostPosted: Fri Mar 10, 2017 4:12 pm    Post subject: Three Miniatures for Electric Guitar Reply with quote  Mark this post and the followings unread
Hey everybody!
I just wanna share with you this compositions, using exclusively electric guitar as sound source.
The first and second are really simple, and unidimensional, just working with chords (major second tuning) from different density levels, or degrees and some modulation things appearing in some very specific points. (ring)
The reverberation level is always the same in the first two pieces... (all of them ocurr on the same space).
The third miniature have 6 layers (tracks) and I've worked with precise pans, volume controls, reverb levels, number of voices on chorus effect, in a contrapontal fashion, using the Trim on Reaper.
I can post some prints from Reaper, showing the Trim lines, if you want.
I'm new in electroacoustic music, so I'm curious to receive some feedback from other experienced composers and guitar lovers!
Thank you for sharing your impressions! (links in order)
https://soundcloud.com/paul-wegmann/miniaturas-para-guitarra-eletrica-1
https://soundcloud.com/paul-wegmann/miniaturas-para-guitarra-eletrica-2
https://soundcloud.com/paul-wegmann/miniaturas-para-guitarra-eletrica-3
PostPosted: Fri Mar 10, 2017 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would listen .. erm .. welcome I meant Laughing
but soundcloud is defect (a policy thing really) ... so .. if you could post something here (as an attachment to a post) I would listen .. I'm always interested in electro-acoustics.
Paul Wegmann
PostPosted: Fri Mar 10, 2017 5:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
done
colheres9.wav
 Filename:  colheres9.wav
 Filesize:  27.44 MB
 Downloaded:  1757 Time(s)
Paul Wegmann
PostPosted: Fri Mar 10, 2017 5:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I apologize! I didn't know Is prohibited to post sound cloud links...
I was searching the rules and I didn't see anything related...
Where can I get that?
Thank you! Greetings from Brazil!
PostPosted: Sat Mar 11, 2017 5:14 am    Post subject: Reply with quote  Mark this post and the followings unread
It is not prohibited - soundcloud just does not work when you do not have flash installed on your computer.
Posting wav files is not the best thing to do though - mp3 is preferred, but ogg and flac will work too.
You have some very nice things going on that wav file though, short, but I like it :-)
Paul Wegmann
PostPosted: Sat Mar 11, 2017 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
You have some very nice things going on that wav file though, short, but I like it Smile
Oh.. I understand! I will post in flac the next time!
Thank for your kind words!
Is short, because is a Miniature... I'm composing a new one, the fourth miniature of the series. I will share soon. Is longer (around 3:40).
Cheers!
