 Forum index » How-tos
Integrate Chuck Machine.add (.ck) file into C or C++ code
Page 1 of 1 [3 Posts]
D.Cio
PostPosted: Sat Jun 23, 2018 8:28 am    Post subject: Integrate Chuck Machine.add (.ck) file into C or C++ code
Subject description: Integrate Chuck Machine.add (.ck) file into C or C++ code
Hi Everybody,
I would like to integrate my .ck file I have renamed HeaderFile into C or C++ as a header file.
I havn't managed to make C nor C++ code recognise the .ck file. Does anybody know if it is possible or actually impossible to integrate a .ck file into C or C++ codes? if yes, how can I do it? do I need to make it into C first and than C++?
Audio files: 297
PostPosted: Sat Jun 23, 2018 5:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi D.Cio and welcome
This would not be possible as chuck code is not C .. but what would you like to accomplish?
Acoustic Interloper
Audio files: 89
PostPosted: Sat Jul 07, 2018 6:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could use the fork and exec system calls to start a chuck command line from a C or C++ process. Not sure if that's what you want, or what this has to do with header files.
When the stream is deep
my wild little dog frolics,
when shallow, she drinks.
