 Forum index » DIY Hardware and Software » The Repair Shop
0v vs. Gnd in Elektor formant.
Page 1 of 1 [2 Posts]
talkboxert
PostPosted: Tue Aug 31, 2021 12:35 am    Post subject: 0v vs. Gnd in Elektor formant. Reply with quote  Mark this post and the followings unread
I'm bringing back to life an old Formant, powering it from a doepfer 12v PSU. The tracking on the VCO's is ok, and one of the VCF's works as well.
As this is a semi modular design, I want to hook up the internal signal path next. This flows from the vcf where all VCO's are internally conected to the VCA and is output on a "COM" module, that has EQ and output sockets.
What i run into is the com pcb, opossed to all other modules has no clear ground connection. In stead it has a connection named 0v.... All the othe modules have the symbol, something like: https://www.mica.co.za/wp-content/uploads/2019/09/TEXT-INSERT-IF-NEEDED-EARTH-GROUND-SYMBOL.jpg
I'm not very good at electronics so apologies if this makes no sense.
But it looks to me like the 0v is derrived from the +/-15v (or in my case 12v) lines by c11,c12.
Do I also connect ground here or leave the 0v unconnected to the rest of the case. I've posted a pic of the schematic that does show a ground symbol on the far left...... The other modules are connected to the ground connection on DC end the doepfer supply (DIY 1 supply). The case is made of wood.
Links, I cant get the image to show up here somehow
https://im.ge/i/QOGzOD
https://im.ge/i/QOGnUp
Audio files: 302
PostPosted: Tue Aug 31, 2021 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
0 is ground there - in the last link you gave.
