SoftMusic
Page 1 of 1 [7 Posts]
PostPosted: Mon Sep 12, 2005 3:56 am    Post subject: SoftMusic Reply with quote  Mark this post and the followings unread
Recent talk here reminded me of SoftMusic ( http://softmusic.sourceforge.net , also reachable via my homepage), which is a Java application that I wrote once. It uses some static, home-made algorithms to create parallel loops of midi notes, that are played using Java's MIDI implementation. It's very simplistic, buggy, and I don't know on which Java versions it works, but someone might get something from it anyway. I certainly had a lot of fun tweaking around while I wrote it. I've been meaning to get to work on it again to straighten out some bugs and implement more cool features, but I never seem to get my thumbs out...
There is a also a manual, with a chapter containing philosophical ramblings about the nature of music. I've always found music interesting because its nature is so elusive - what exactly is music and what is it really good for? The answer to this is something that my body knows, but it is hard to put down in words.
Stefan Blixt
Audio files: 297
PostPosted: Mon Sep 12, 2005 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for reminding me ... but ... do I really need Java 1.4.something ?
Forgive when this is a stupid question, I know next to nothing about Java.
When I try under 1.5.0 (well I think I use that, but there might be other versions present as well, how can I find out ? And I had to modify softmusic.smc a bit to find a file soundbank.gm in a different place) I get this :
Code:
D:\Download\Music\SoftMusic\softmusic>java -cp bin antimon.softmusic.SoftMusic
Welcome to SoftMusic!
  class com.sun.media.sound.MixerSynth
    class com.sun.media.sound.AbstractPlayer
      class com.sun.media.sound.AbstractMidiDevice
        class java.lang.Object
Device #0: US-122 MIDI Port:No details available
Device #1: Microsoft MIDI Mapper:Windows MIDI_MAPPER
Device #2: Microsoft GS Wavetable SW Synth:Internal software synthesizer
Device #3: SynC Modular:External MIDI Port
Device #4: US-122 MIDI Port:External MIDI Port
Device #5: Real Time Sequencer:Software sequencer
Device #6: Java Sound Synthesizer:Software wavetable synthesizer and receiver
File C:\Program Files\Java\jre1.5.0\lib\audio\soundbank.gm contains soundbank co
m.sun.media.sound.HeadspaceSoundbank@ad8659
Loading instruments...
Bad note value in chord.smc: 7
Program change: bank 0 program 0
Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: Color
 parameter outside of expected range: Red Green Blue
        at java.awt.Color.testColorValueRange(Unknown Source)
        at java.awt.Color.<init>(Unknown Source)
        at antimon.softmusic.RythmPanel.paintComponent(RythmPanel.java:21)
        at javax.swing.JComponent.paint(Unknown Source)
        at javax.swing.JComponent.paintChildren(Unknown Source)
        at javax.swing.JViewport.paint(Unknown Source)
        at javax.swing.JLayeredPane.paint(Unknown Source)
        at javax.swing.JComponent.paintWithOffscreenBuffer(Unknown Source)
        at javax.swing.JComponent.paintDoubleBuffered(Unknown Source)
        at java.awt.GraphicsCallback$PaintCallback.run(Unknown Source)
        at sun.awt.SunGraphicsCallback.runOneComponent(Unknown Source)
        at sun.awt.SunGraphicsCallback.runComponents(Unknown Source)
        at java.awt.Container.paint(Unknown Source)
        at sun.awt.RepaintArea.paintComponent(Unknown Source)
        at sun.awt.RepaintArea.paint(Unknown Source)
        at sun.awt.windows.WComponentPeer.handleEvent(Unknown Source)
        at java.awt.Component.dispatchEventImpl(Unknown Source)
        at java.awt.Container.dispatchEventImpl(Unknown Source)
        at java.awt.Window.dispatchEventImpl(Unknown Source)
        at java.awt.Component.dispatchEvent(Unknown Source)
        at java.awt.EventQueue.dispatchEvent(Unknown Source)
        at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
        at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
        at java.awt.EventDispatchThread.run(Unknown Source)
And the application's main screen is only painted when I move the mouse over it.
Any clues ?
DrJustice
PostPosted: Mon Sep 12, 2005 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Stefan!
Thank you for the softmusic program!
It's working here on Sun J2RE 1.4.2, playing away as I type this. I haven't applied the pacth yet (I guess I should). It can find a soundbank when starting (there's no lib/audio in my Java install..) so it says it's reverting to default sounds.... Looks like fun, Im going to have play.
DJ
PostPosted: Tue Sep 13, 2005 12:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for trying it out Very Happy
Jan, I'm sorry that the thing doesn't work for you Embarassed , I can't say straight away what is going on with that stack trace. I know a few things happened with the Swing code (handling graphical interface stuff) in later versions, so it might have something to do with that. If you want to, you could install JRE 1.4 (which seems to work for DJ) from java.sun.com, and point SoftMusic to it.
Now I really have to dig out the old source code and start fixing things... I'll post a notice here if I manage to recreate and fix the java.lang.IllegalArgumentException problem.
Audio files: 297
PostPosted: Tue Sep 13, 2005 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I tried to install 1.4.2_02, well I succeeded actually, but when I popup the Java console it still says I'm still using 1.5. So I tried to disable it in the console, tried adding the 1.4 path to the path environment, restored the original config giles, but unfortunately I still get the same results, more or less.
I got it to play some stuff, but it's a bit hard with the user interface disappearing all the time :-)
When you feel like fixing it please let me know, I've a liking for random players. But when it's just for me please don't do anything you'd rather not do.
It reminds me a bit on a similar program I once wrote, but I lost that one and the sources as well, it probably is somwhere in this pile of old harddisks that I've got laying around ...
bachus
PostPosted: Tue Sep 13, 2005 5:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I have to report much the same problems as blue hell.
Reminds me of a wagish saying about java:
while it was supposed to be "write once, run everwhere"
it turned out "write once, debug everwhere"
Anyway it did look interesting. Keep us updated if you get back into it.
DrJustice
PostPosted: Tue Sep 13, 2005 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm using v 1.4.2_01 to be exact.
In my posting above I wrote "It can find a soundbank..." - that sould be "...can't...". Do I just find a .gm file somwhere and drop it into <java>/lib/audio/ ?.
DJ
