today> Sorry, no show today/tonight Chez Mosc
Whacky synth issues
Page 1 of 1 [14 Posts]
Axiom
G2 patch files: 28
PostPosted: Sat Sep 17, 2005 4:02 pm    Post subject: Whacky synth issues Reply with quote  Mark this post and the followings unread
Ok, after some checks now this thing seems to work. It make some noises but i've got two main problems:
- The Zany volume is very low. I can have a decent volume only if i touch an R12 contact with one of my multimeter probe. I've also tried to replace the resistor but nothing happens.
- The filter doesn't seems to work. Turning R8 knob don't produce any change in the sound.
Tomorrow I will post some pics of my awful work Razz
Luca
Posted Image, might have been reduced in size. Click Image to view fullscreen. Posted Image, might have been reduced in size. Click Image to view fullscreen.
PostPosted: Sat Sep 17, 2005 4:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Check your ground connections. I built a PaiaFatman some time ago, and when wiring the knobs, I left a ground connection floating. The synth seemed to work, except envelopes did some wired things, etc. The problems you have sound like you might not have the ground (or power if that's what it's connected to) connected on the volume and filter pots.
PostPosted: Sat Sep 17, 2005 4:32 pm    Post subject: Re: Whacky synth issues Reply with quote  Mark this post and the followings unread
Luca,
This DOES sound like a dry-joint!!!! See my other post :D
PostPosted: Sat Sep 17, 2005 6:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah well, a wet joint would be real trouble, so what worry :-)
Axiom
G2 patch files: 28
PostPosted: Sun Sep 18, 2005 2:44 am    Post subject: Reply with quote  Mark this post and the followings unread
here are a pic of my pseudowork and a little clip with shows you my issues
Download movie
Luca
 Filesize:  35.08 KB
 Viewed:  12915 Time(s)
PostPosted: Sun Sep 18, 2005 3:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Luca,
Ouch! that's gotta hurt! (imagine bronx-type accent!!)
I wish the pic here was at a higher resolution- as it's difficult to see exactly what is going on here. Can you send some macro/ close up shots too??
PostPosted: Sun Sep 18, 2005 3:18 am    Post subject: Reply with quote  Mark this post and the followings unread
unfortunately the movie doesn't appera to play on my VLC player either- wma files never do- I can only get audio...
Axiom
G2 patch files: 28
PostPosted: Sun Sep 18, 2005 3:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Here are an high resolution pic and the video recompiled in Xvid.
High Res picture
Xvid video
Luca
p.s.: i've removed the wmv video posted before.
PostPosted: Sun Sep 18, 2005 4:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Luca,
a bit dark maybe- but I could see what was going on :)
Get some desoldering braid and put it over the joint pressing the Iron into the braid. This should take all the solder off- you could also use a pump, but this can be a bit messy- but both are useful tools to own.
To me it sounds pretty fun and cool. I also love you crazy layout. Put it down to experience and do another!!
Tom :)
Axiom
G2 patch files: 28
PostPosted: Sun Sep 18, 2005 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
ok Smile i've put the crapboard into a carton box Very Happy i've connected it into my G2X and i've made a patch to control it like an oscillator.
Listen to this MP3
Luca
link fixed Razz
PostPosted: Sun Sep 18, 2005 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Not Found
The requested URL /files/wachy_g2.mp3 was not found on this server.
Axiom
G2 patch files: 28
PostPosted: Sun Sep 18, 2005 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
fixed Razz
Luca
PostPosted: Sun Sep 18, 2005 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Thx, thats some interesting sounds going on.
How exactly did you make this (I dont seem to quite get it from the thread sofar) ?
Axiom
G2 patch files: 28
PostPosted: Sun Sep 18, 2005 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've used 3 Level Amp to get whacky sound at a decent level. i've put it and a sine wave into a Mixer2 to tune the analog oscillator. I've connected the mix output to a Pitch Shifter and used Pitch controller from KBD block to tune the oscillator. A filter and an ADSR do the rest Razz
Luca
