Alan has done it again!!!!
Page 1 of 1 [8 Posts]
Wild Zebra
PostPosted: Mon Sep 19, 2005 7:07 am    Post subject: Alan has done it again!!!! Reply with quote  Mark this post and the followings unread
http://www.musicfromouterspace.com/analogsynth/photogallery.html
oh, oh, oh I want one of those. Sweet joystick Alan. Another excellent looking Sound Lab with another cool feature.
"your stripes are killer bro"
PostPosted: Mon Sep 19, 2005 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Come on Albut- It's a Synthi AKS you really want isn't it?
:D
Albut
PostPosted: Mon Sep 19, 2005 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
No I don`t want an AKS, but I do want a joystick on me Sound Lab. A bargain ar £4-50 +vat from RS components. Everyone should have one.
I had a VCS3 for 3 years in the 80`s so I have got that yearning for one out of the way now. Not much more on it than a Sound Lab anyway.
"put an egg in your boot and beat it"
Wild Zebra
PostPosted: Mon Sep 19, 2005 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
HI Albut,
So where's the secret joystick layout Very Happy? So everyone can have one.
It would be much appreciated.
Albut
PostPosted: Mon Sep 19, 2005 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
There is no layout. It`s simple.
I used the joystick with 100k pots.
There are 2 pots on the joystick. On each one fit a 10k resistor to the 2 outside pins of the pots. Connect +v to the 2 left resistors and -v to the 2 right resistors (or reverse them depending on which way you want the voltage swing from the joystick) The centre pins of the pots are the CV outputs. I have put an output level pot for each one and these are routed via switches to VCOs etc.
There is also a switch built into the joystick you can use to trigger the AR gen if you want, but I didn`t use it.
PostPosted: Mon Sep 19, 2005 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
£4.50??? That's a bargain indeed.
is this the one by any chance? ;
http://rswww.com/cgi-bin/bv/initSession.jsp?stockNo=4568241&store=uk
Albut
PostPosted: Mon Sep 19, 2005 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep. That`s it.
Wild Zebra
PostPosted: Mon Sep 19, 2005 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Albut,
That sure looks like it v-un-v. Looks like eventually I'm gonna have to make another SL with all these fancy things all you clever folks keep adding.
