Oscless9
Page 1 of 1 [2 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Thu Dec 29, 2005 12:32 pm    Post subject: Oscless9
Subject description: no oscillators again
Here is another oscillator-less patch. The AD/R envelope has a End out which can be patched back to the Gate input for cyclic waveforms. This envelope uses a lot of zero page memory for some reason, so is probably the envelope module I use least.
The EnvMulti can do a similar self triggering trick, in bipolar mode, set the final level to 1 and all the other levels <= 0, patch the out to the gate and you have an oscillator with four slope rates and 3 variable levels. This patch shows it used as a bank of eight audio oscillators and again as an LFO.
OScLess9.pch2
env as osc
 Filename:  OScLess9.pch2
 Filesize:  2.43 KB
 Downloaded:  1971 Time(s)
cebec
G2 patch files: 31
PostPosted: Thu Dec 29, 2005 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks, ian. this took me on an enjoyable tangent that led to clocking various rnd modules with osc's and sending the output of a rnd module to it's own reset input.
