 Forum index » Clavia Nord Modular » G2 Patches - Completed » Classic
DX100, DX27 and DX21 emulation
Page 1 of 1 [7 Posts]
Burp
G2 patch files: 7
PostPosted: Mon Mar 19, 2007 9:14 am    Post subject: DX100, DX27 and DX21 emulation
Subject description: 4op FM synth with Solid Bass variation
My first post after a couple of months reading all kind of posts around here. Very helpfull!! Thanx all!
I have a G2 key now for a few months now, great thingy! Much more playeble than the NM1 which i had before. I still own a Micro because its so small and flexible. (And some other gear Wink
But back to the topic:
An emulation of my first synth, the Yamaha DX21, just because i like some of the sounds and was curious if i could get them out of the G2, and yes, it can get close.
Thanks to 3phase for the 4op router!
As you can see i´ve added a digitizer to get the lo-fi sound and a LowBoost to get the low-end sounds more like my DX21.
I put some variations in that i liked and the much wanted Solid Bas.
Grtz
-Jan
DX21.pch2
DX21 (and DX100,DX27) emulation.
 Filename:  DX21.pch2
 Filesize:  4.32 KB
 Downloaded:  2066 Time(s)
if you don't know where you're going, you will allways arrive
PostPosted: Mon Mar 19, 2007 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Jan
welcome to electro-music.com!
I can't load this into the demo version, which is crazy because it's only supposed to be an FM patch. Any chance of a demo-friendly version?
ACHTUNG!
G2 patch files: 626
PostPosted: Mon Mar 19, 2007 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
Hi Jan
If not you could try lately bass or solid bass (a DX2G2 translation).
The former might translate better as it does not use the router or DXoperator.
PostPosted: Mon Mar 19, 2007 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nope. The second one don't work, the first one does. However it sounds too squidgy to me- ie it ain't 'solid'.
Thanks anyway. I should get my micro up and running again, but I spend too much time gassing on electro-music.com Shocked Very Happy
ACHTUNG!
Audio files: 274
PostPosted: Mon Mar 19, 2007 1:40 pm    Post subject: Re: DX100, DX27 and DX21 emulation
Burp wrote:
Hi Jan welcome I had seen you on the member list a while ago and had a good time then checking out your website.
G2 patch files: 626
PostPosted: Mon Mar 19, 2007 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
The solidbass is a little more solid, the extra two operators help. Latelybass is from TX81Z, and though not quite as solid, has that nice rubber band effect at higher velocity.
Oh, Burp. Nice patch, I like a lot of those variations.
Burp
G2 patch files: 7
PostPosted: Tue Mar 20, 2007 12:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi all, thanx for the welcome (and looking at my site Wink, i did check yours also and had a nice time to jan).
I don't know actualy if the lately bass is the same as the solid bass, but the latter is a nice one. Although i never used it. I like the more odd sounding thingies Very Happy
grtz
-Jan
