Ballistic Spring Bouncer
Page 1 of 1 [4 Posts]
Tim Kleinert
G2 patch files: 236
PostPosted: Thu Jun 07, 2007 6:05 am    Post subject: Ballistic Spring Bouncer
Subject description: spring bounce generator with spring stiffness
As the title says.
Demo modules demonstrate implementation.
Spring stiffness and initial energy are adjustable.
SpringBouncer TK.pch2
 Filename:  SpringBouncer TK.pch2
 Filesize:  1.68 KB
 Downloaded:  1809 Time(s)
Audio files: 308
PostPosted: Mon Jun 11, 2007 2:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I see you've been quite too much coffee for a while, hope things are better now Very Happy
Nice patches !
3phase
G2 patch files: 141
PostPosted: Sat Jun 16, 2007 2:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Tim,
I am still after the fx of 2 interacting springs and have found this webpage where a java simulation software is running..
Do you have any idea how to translate that into a g2 patch?
would be quite a hack...
http://www.myphysicslab.com/spring2d.html
http://www.myphysicslab.com/dbl_spring2d.html
http://www.myphysicslab.com/spring1.html[/right]
Audio files: 308
PostPosted: Sat Jun 16, 2007 6:26 am    Post subject: Reply with quote  Mark this post and the followings unread
http://electro-music.com/forum/post-33333.html shows a way to implement differential equations, also look at mergerov's patch at the bottom for a different approach.
The 2d spring examples use square root and division, see http://electro-music.com/forum/post-31440.html for that.
It's quite a bunch of equations to implement indeed.
