nuriel77
Joined: Apr 03, 2004 Posts: 24496 Location: The Netherlands, Enschede
Posted: Sat May 24, 2008 5:14 pm Post subject:
I'm not sure what you mean, but in the attached patch it looks like there are no morphs at all.
To use morphs you click on the knob for the morph you want to use to make it the focused morph.
Then you click/drag on the knobs that you want to be in that morph group to set their morph range from some minimum to some maximum value.
Then when you change the morph knob (or when it is associated with some controller (which it is by default), the associated controller (like the pitch stick or the mod wheel)) the effect is that the morph controls the knobs that are in the group.
I think the manual does a better job in explaining it  _________________ Jan
nuriel77
Posted: Sun May 25, 2008 4:22 pm Post subject:
morphs... |
| Blue Hell wrote: | I'm not sure what you mean, but in the attached patch it looks like there are no morphs at all.
I think the manual does a better job in explaining it  |
Hey Jan,
I know how to assign morphs I always manage to assign / use morphs.
what happened to me on this patch: I do manage to assign parameters to the various morphs, but when i try to use them, nothing works! (Try to assign the modwheel to one or more parameters like freq cutoff, and see if it does anything?)
Thnks. |
G2 patch files: 626
Posted: Sun May 25, 2008 5:01 pm Post subject:
Nice prf
Slot A has the button under mod morph set to knob which disables the physical mod wheel.
I thought I had the same problem as you reported, until I realised I hadn't set the keyboard focus the the slot I was playing with.
Assigning and using mod wheel morphs seems to work here on my G2 key. |
Posted: Sun May 25, 2008 5:07 pm Post subject:
Re: morphs... |
| nuriel77 wrote: | I know how to assign morphs I always manage to assign / use morphs. |
Ok, I didn't see any, so I thought that was the problem ...
| Quote: | (Try to assign the modwheel to one or more parameters like freq cutoff, and see if it does anything?)
That doesn't work for an engine, so I can't try unfortunately. _________________ Jan
nuriel77
Posted: Mon May 26, 2008 5:12 pm Post subject:
Re: morphs... |
| Blue Hell wrote: | | nuriel77 wrote: | I know how to assign morphs I always manage to assign / use morphs. |
That doesn't work for an engine, so I can't try unfortunately. |
Hi!
Well I got the answer I needed. I had to read more in depth in the manual. I was sure I already went over the chapter of morphs, but I forgot that under the morph knobs there are also buttons! And I didnt see when I started the performance that the button under the control pedal and modwheel where actually set to knob
I need to thank Rob for solving this simple issue for me!
thanks for trying to help though
best regards,
nuriel
Sorry I was maybe unclear about what it was I was trying to get done... |
