 Forum index » Clavia Nord Modular » G2 Patches - Completed » Drum
303 Base
Page 1 of 1 [3 Posts]
3phase
G2 patch files: 141
PostPosted: Thu Feb 24, 2005 10:10 am    Post subject: 303 Base Reply with quote  Mark this post and the followings unread
THe first patch of my new 303 go...one every year...
This time i left out all soundmedeling and detail emulation and started from the main buildingblocks of a 303 circuit...
They are all there and functional...together with the allready hacked 303 sequencer (G203 performances) this gives an good 303 modell allready.
The attached patch with its only 50% is a good starting point for 303 alikes... with the wright sequencer control it behaves like one...
Next steps will be to import the osc modeling of my previous versions and building of a DIY filter that trys to get the 303 sound better than the standard filter can do...
303 Base 0.2.pch2
 Filename:  303 Base 0.2.pch2
 Filesize:  3.82 KB
 Downloaded:  2289 Time(s)
General Elektrick
PostPosted: Fri Feb 25, 2005 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Wink
Sounds like the real stuff!
thanks for sharing
Best,
General Elektrick
"If something is boring after two minutes, try it for four. If still boring, then eight. Then sixteen. Then thirty-two. Eventually one discovers that it is not boring at all." --John Cage.
Roland Kuit
G2 patch files: 127
PostPosted: Sat Feb 26, 2005 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeppy, this will be good for GOA nights when you pattern or sequence this.Thanx for sharing.
