G2 metronome
Page 1 of 1 [2 Posts]
Calude Voiot
G2 patch files: 5
PostPosted: Fri Aug 05, 2005 7:32 am    Post subject: G2 metronome Reply with quote  Mark this post and the followings unread
Hi
i've been patching/learning again a lot since my G2 Engine arrived beginning of July.
Here is a little metronome I've been working on since yesterday and I'm stuck on the last details.
Its sort of a Boss DRythm 33 emulation .
I have the beat going and I am superposing 1/4 note triplets to it. as you know every 3 they line up.
My idea was to cut the 1/4 note triplet trigg each time it lines up with the beats
In the attached patch you can find the problem area in red at the bottom.
And the question is: how to use the "beats" to cut out the 1/4 note triplet trigg that line up with it.
I almost forgot, this was patched on the pc 1.32 Demo (maybe useful??)
Merci beaucoup
Calude
metronome_cv6.pch2
 Filename:  metronome_cv6.pch2
 Filesize:  3.34 KB
 Downloaded:  1195 Time(s)
Calude Voiot
G2 patch files: 5
PostPosted: Sat Aug 06, 2005 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I found the answer to my problem myself. Cool
the lesson is : when comparing triggs with a logical gate it is wise to take the signal for comparing as close to the clock source as possible....
the finished patch is in the "appropriate" folder
http://electro-music.com/forum/topic-7375.html
did we need a metronome for the G2 ??? Laughing
Calude
oh and BTW it is a Dr. Beat 66 and not a Dr.rythm 33 ...........
