chresan
Joined: Jul 11, 2006 Posts: 150 Location: Karlsruhe, Germany
Posted: Tue Mar 11, 2008 10:30 am Post subject:
2008/03/11 Nomad 0.3 pre-release Update 2 available for DL |
we published an update of the Nomad 0.3 release right now .
Fixes
- module pane does not show modules
- module/connector popup not shown
- Invalid plug exception -> no connection possible
| Code: |
net.sf.nmedit.jsynth.SynthException: Invalid plug MidiPlug[name=MIDI HUBBLE MIDI 2,vendor=Unknown vendor,description=No details available] for net.sf.nmedit.jsynth.midi.MidiPort[name='pc-out',type=TRANSMITTER,plug=MidiPlug[name=Microsoft MIDI-Mapper,vendor=Unknown vendor,description=Windows MIDI_MAPPER]].
at net.sf.nmedit.jsynth.midi.MidiPort.setPlug(MidiPort.java:110) |
Please download the updated release from http://nmedit.sourceforge.net/
I am very sorry this happened.
Christian _________________ ----------------------
http://nmedit.sf.net |
nathan
Posted: Tue Mar 11, 2008 10:38 am Post subject:
very nice guys!
we'll get at the perfect editor, step by step, altogether hand in hand.
nathan
Posted: Tue Mar 11, 2008 11:15 am Post subject:
only weird thing now is that the knobs dont turn visually correct.
but only visually. weird.. |
gomidas
Joined: Jul 09, 2004 Posts: 247 Location: La Ciotat, France
G2 patch files: 6
m:o
Posted: Tue Mar 11, 2008 11:27 am Post subject:
Big thanks to you !! Works like geschnitten brot here !
You have really made a lovely work on this - the only thing to make me perfect happy is to find the switch between horizontal and vertical mouse control.......am i blind? |
gomidas
G2 patch files: 6
Posted: Tue Mar 11, 2008 11:34 am Post subject:
m wrote: | Big thanks to you !! Works like geschnitten brot here !
Hello m , do you use mac or win? ppc ,intel? osxmidispi or other? Sorry to bother my friend it's just to know...
Thanks |
m:o
Posted: Tue Mar 11, 2008 11:43 am Post subject:
Hey gomidas!
im on a windows desktop with XP Sp3 and a Terratec MidiHubble as Midi i/o.
I guess you're on a mac, so i can't help - sorry. |
gomidas
G2 patch files: 6
Posted: Tue Mar 11, 2008 11:50 am Post subject:
Ok!!!!! cool!!!!
Have fun m |
wesen
Posted: Tue Mar 11, 2008 12:14 pm Post subject:
Hey gomidas,
I have the exact same config as you, but mmj and osxmidispi work for me. What is the problem when you use those? Is the EDIROL not recognized?
Regards, manuel |
chresan
Posted: Tue Mar 11, 2008 12:36 pm Post subject:
Hi gomidas,
when you tried our osxmidispi, did you remove the other SPIs (mmj,mandalone) ? It could be that they interfere with each other.
Christian
P.S.: Java 1.5 = Java 5, Java 1.6 = Java 6 _________________ ----------------------
gomidas
G2 patch files: 6
Posted: Tue Mar 11, 2008 1:18 pm Post subject:
I will try this as soon as I get back home...thanks for the tip  |
gomidas
G2 patch files: 6
Posted: Wed Mar 12, 2008 1:24 am Post subject:
AND AGAIN.. MACROS RUUUUUULES!!!!!!!!!!!!  Last edited by gomidas on Sat Mar 22, 2008 5:52 am; edited 1 time in total |
gomidas
G2 patch files: 6
cebec
Joined: Apr 19, 2004 Posts: 980 Location: Alexandria, VA
G2 patch files: 31
Posted: Thu Mar 20, 2008 4:51 pm Post subject:
Anyone find a way to switch between horizontal and vertical mouse control of knobs in the editor? |
chresan
Posted: Thu Mar 20, 2008 5:13 pm Post subject:
| cebec wrote: | | Anyone find a way to switch between horizontal and vertical mouse control of knobs in the editor? |
Currently there is no way to change the behaviour. But in one of the next releases there will be such an option. _________________ ----------------------
cebec
G2 patch files: 31
Posted: Thu Mar 20, 2008 6:06 pm Post subject:
Cool. Just checking. Keep up the great work!
starpause
Joined: Feb 26, 2008 Posts: 6 Location: san francisco
Posted: Thu Apr 03, 2008 9:15 pm Post subject:
when i start nomad-0-3_2 with "java- jar nomad.jar" on my ubuntu desktop nomad launches fine.
however, i can not connect to my micromodular. in fact, i can't even go to edit->preferences or file->preferences (both options are grayed out).
i was able to connect with the previous version of the editor.
any advice? thanks in advance and glad to see a new version!
edit:
after watching the screencasts i tried to connect to my micromod but got this error:
| Code: |
net.sf.nmedit.jsynth.SynthException: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:411)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.setConnected(NordModular.java:881)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.trySetConnectedState(SynthObjectForm.java:958)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$1$1.run(SynthObjectForm.java:599)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:273)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:183)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:173)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:168)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:160)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:121)
Caused by: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jnmprotocol2.NmMessageAcceptor.waitForReply(NmMessageAcceptor.java:111)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:400)
... 11 more
wanted to add that i'm using the midisport uno 1x1 ...
is there a tool like midiox for linux or mac osx? i think it's working though because the last version of nomad could connect. Last edited by starpause on Fri Apr 04, 2008 8:09 pm; edited 2 times in total |
Joined: Apr 03, 2004 Posts: 12350 Location: Netherlands, Enschede
Audio files: 32
G2 patch files: 301
Posted: Fri Apr 04, 2008 2:52 pm Post subject:
Just tried Nomad 0-3_2 on Vista with Java 1.6 with and Edirol UM-3ex, no good, no connection
It looks like a timeout on the heart beat ... would that be the real problem or could it be that MIDI is not neatly grouped into completed messages (an issue I've ran into at times with MIDI on windows)?
The Clavia editor seems to work on this config, although I didn't really test it yet.
Edit : I Do have the synth set for internal clock.
Anyway, here is my dump :
| Code: |
net.sf.nmedit.jsynth.SynthException: net.sf.nmedit.jnmprotocol2.MidiException: Communication timed out: 1207345072963 [error=-1001]
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Caused by: net.sf.nmedit.jnmprotocol2.MidiException: Communication timed out: 1207345072963 [error=-1001]
at net.sf.nmedit.jnmprotocol2.NmProtocol.heartbeatImpl(NmProtocol.java:58)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular$SchedulingProtocol.heartbeatImpl(NordModular.java:252)
at net.sf.nmedit.jnmprotocol2.AbstractNmProtocol.heartbeat(AbstractNmProtocol.java:154)
at net.sf.nmedit.jnmprotocol2.NmMessageAcceptor.waitForReply(NmMessageAcceptor.java:114)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:358)
... 11 more
_________________ Jan |
chresan
Posted: Sat Apr 05, 2008 5:14 am Post subject:
BlueHell:
We did not test Nomad on Vista because none of us has this OS. Nomad contains some code which tries to "correct" invalid sysex messages and I believe this causes some of the timeout problems. At the moment I can't say more than I will look into this.
chresan
Posted: Sat Apr 05, 2008 5:18 am Post subject:
starpause:
The current release contains a bug which causes this exception. You have to set the synth midi clock to "internal" as workaround.
midisport + ubuntu should not cause any problems.
chresan
Posted: Sat Apr 05, 2008 10:58 am Post subject:
Bon appetite!  _________________ ----------------------
Audio files: 32
G2 patch files: 301
Audio files: 32
G2 patch files: 301
Posted: Sat Apr 05, 2008 11:00 am Post subject:
| chresan wrote: | Bon appetite!  |
Danke schön
edit: oh this got a bit weird due to the split off, ah well, "dinner time" was what I said in the other thread. _________________ Jan |
starpause
Posted: Mon Apr 07, 2008 7:17 pm Post subject:
chresan, thank you! i will try that out.
any1 know if it's possible to set the midi clock to internal from the micro modular front panel? i don't see how and it's not mentioned in the manual. if not i will take my micro to work and use the windows editor  _________________ myspace |
starpause
Posted: Mon Jul 21, 2008 12:59 am Post subject:
update: i just checked my nord micromodular with "Nord modular editor v3.03" under windows, looks like i already had MIDI clock to internal. i tried toggling it back and forth just for good measure and starting nomad with the MIDI clock to both internal and external but "Preferences" was still grayed out in nomad's Edit menu, even under winXP
is this something that might be fixed in the head CVS build?
thanks! _________________ myspace |
