jhaible
Posted: Wed Jul 23, 2008 4:08 pm Post subject:
Today I made a short visit at Touched by Sound, and it seems that they are now starting to gear up for producing ready-made phasers with my "Krautrock Phaser" PCBs. There was a guy who specializes in metalwork / enclosures, and another one who is ordering the components and will do the soldering. Seems they are now starting in earnest!
(I'm not really involved except selling them the PCBs, but of course I'm interested to see how things are developing!)
JH. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
wooster
Posted: Fri Aug 01, 2008 6:28 am Post subject:
I just got my phaser working last night. Well, mostly working. I feel like it needs to be better calibrated. Any tips for setting the range and resonance trimmers?
Here are some parts I used which worked fine:
Relay: Tyco V23105A5403A201 (from Mouser)
Heatsink: Aavid Thermalloy 523002B00000G (from Mouser) - this one fits the footprint perfectly
For the front panel lamp holder, I got a quote from Domax to order 500 pcs for $0.38 each, but I think I was making things too hard. I saw these when I went to buy batteries one day:
Front panel lamp holder: Radio Shack 272-325 - it fits the E10 bulbs I have, and works even though the bulbs don't have little tabs to twist into the base.
edit: I didn't mean to sound unenthusiastic in the first sentence, this phaser is really cool. |
jhaible
Posted: Fri Aug 01, 2008 7:21 am Post subject:
wooster wrote: | I just got my phaser working last night. Well, mostly working. I feel like it needs to be better calibrated. Any tips for setting the range and resonance trimmers?
With Feedback potentiometer on cw end position, adjust resonance trimmer such that the oscillation just stops.
Adjust Range trimmer by ear for pleasant sweep range.
numbertalk
Posted: Fri Aug 01, 2008 7:45 am Post subject:
Thanks I was wondering about setting the trimmers as well.
Any tips on setting the LowLim trimmer as well?
jhaible wrote: | wooster wrote: | I just got my phaser working last night. Well, mostly working. I feel like it needs to be better calibrated. Any tips for setting the range and resonance trimmers?
JH. |
jhaible
Posted: Fri Aug 01, 2008 12:05 pm Post subject:
numbertalk wrote: |
Only interesting with a volume pedal connected to the AMOUNT jack.
The trimmes sets a lower limit for the heel position of the pedal.
numbertalk
Posted: Fri Aug 01, 2008 12:16 pm Post subject:
jhaible wrote: |
JH. |
Good to know - thanks! |
markusw
Joined: Jun 16, 2007 Posts: 23 Location: Vienna/Austria
Posted: Tue Aug 05, 2008 10:54 pm Post subject:
What actually is the reason for the two jumpers close to the "in " and "out" connectors layout-wise?  |
jhaible
Posted: Wed Aug 06, 2008 12:21 am Post subject:
markusw wrote: | What actually is the reason for the two jumpers close to the "in " and "out" connectors layout-wise?  |
I was somehow anticipating that it could be easier to fond 6.3V lamps than 7V in some parts of this world, and as an ordinary silicon diode has approximately 0.6 ... 0.7V voltage drop I thought I'd provide two wire bridges that could be replaced with two 1N4002 diodes in that case.
I have not tested this, though - and with Tobias now officially selling parts for my PCBs 7V lamps shouldn't be a problem anywhere in the world ...
markusw
Posted: Wed Aug 06, 2008 4:48 am Post subject:
jhaible wrote: |
JH. |
Thanks a lot for your explanation, Jürgen!
I thought placing the two jumpers the way you did was some highly sophisticated trick for e.g. noise minimisation  |
numbertalk
Posted: Sun Aug 10, 2008 6:56 pm Post subject:
Quote: | Now, there is als the possibility to just use a *single* 16 ... 18V winding, or a 16 ... 18v AC (AC !) Wallwart, and just connect it to pins 1 and 2 of the 5Pin connector. |
Does this mean if using a wallwart you could also leave off the fuse connected to pin 5? Seems like it but wanted to check first.
Also, I've never used AC directly like this so I just wanted to triple check before I proceed that it doesn't matter which of the 2 conductors from the wallwart plug goes to which of pins 1 & 2 on the board, right?
Finally, with the wallwart setup, do you recommend any extra SMD bypass caps (in addition to upgrading to the 1000uf caps) or still just the 2 near the regulators are okay(I'm also planning to use 741s)?
Thanks! |
jhaible
Posted: Mon Aug 11, 2008 12:36 am Post subject:
numbertalk wrote: | Quote: | Now, there is als the possibility to just use a *single* 16 ... 18V winding, or a 16 ... 18v AC (AC !) Wallwart, and just connect it to pins 1 and 2 of the 5Pin connector. |
Yes.
Quote: | Also, I've never used AC directly like this so I just wanted to triple check before I proceed that it doesn't matter which of the 2 conductors from the wallwart plug goes to which of pins 1 & 2 on the board, right? |
The AC from the wallwart is floating (and it must not have any connection elsewhere than to pin 1 and 2 of this connector! And you *must* use an insulated jack for connecting the wall wart when using a metal enclosure!), so the two are interchangeable.
If they come from the wall wart with a shielded cable (some but not all wallwarts have this), I recommend the shield to go to Pin 2, and t einner wire to go to pin 1. But that's not crucial.
No need for extra SMD caps - it's the big electrolytics that will take care of the (much) higher ripple of half wave rectification.
How much these caps have to be increased (and if they have to be increased at all) depends on the wallwart you're using.
Don't think too much about it, just try it - if the cap is too small, you'll get some hum, so you solder in a bigger cap.
numbertalk
Posted: Mon Aug 11, 2008 7:50 am Post subject:
Quote: | And you *must* use an insulated jack for connecting the wall wart when using a metal enclosure!) |
So a plastic jack is insulated, right?
Thanks for all the info - greatly appreciated! |
jhaible
Posted: Mon Aug 11, 2008 11:13 am Post subject:
numbertalk wrote: | Quote: | And you *must* use an insulated jack for connecting the wall wart when using a metal enclosure!) |
Well it *should*.
The criterium is that no metal part that carries the AC voltage has any conductive connection to the metal pnel the jack is mounted on ...
numbertalk
Posted: Mon Aug 11, 2008 12:41 pm Post subject:
Gotcha - thanks!
jhaible wrote: | numbertalk wrote: | Quote: | And you *must* use an insulated jack for connecting the wall wart when using a metal enclosure!) |
Well it *should*.
JH. |
numbertalk
Posted: Tue Aug 12, 2008 6:08 pm Post subject:
What would I use if I wanted to insulate the transistors/regulators from the heat sinks? I've never used component heat sinks before - is there something specifically I could find at Mouser or somewhere?
Also my heat sinks didn't come with screws/bolt - any easy way to find the right one to fit the TO-220 components to the heat sinks other than to take a component and heat sink to the hardware store to figure it out?
Thanks. |
wooster
Posted: Tue Aug 12, 2008 6:39 pm Post subject:
numbertalk wrote: | What would I use if I wanted to insulate the transistors/regulators from the heat sinks? I've never used component heat sinks before - is there something specifically I could find at Mouser or somewhere? |
You DONT want to thermally insulate the transistors, you want to thermally couple them. Heat sink compound is commonly available at computer stores, but I doubt it is necessary. I don't know a good way to electrically insulate the transistors without risking thermal insulation. Are you worried that the heat sink will come in contact with the chassis?
numbertalk wrote: | Also my heat sinks didn't come with screws/bolt - any easy way to find the right one to fit the TO-220 components to the heat sinks other than to take a component and heat sink to the hardware store to figure it out?
Do you have a ruler? If so, then you can measure the hole! I used some 6-32 x 1/2 machine screws that I happened to have in my drawer. They're a little long but fit okay. |
numbertalk
Posted: Tue Aug 12, 2008 7:10 pm Post subject:
wooster wrote: |
You DONT want to thermally insulate the transistors, you want to thermally couple them. Heat sink compound is commonly available at computer stores, but I doubt it is necessary. I don't know a good way to electrically insulate the transistors without risking thermal insulation. Are you worried that the heat sink will come in contact with the chassis? |
I was looking for electrical insulation, though it sounds like I'm risking thermal insulation by doing so. I'm just concerned about the heat sinks touching each other. I got some from Mouser which I don't think I'd be able to solder in. They don't seem to quite fit the foot print as well as it sounds like the ones you mention finding there earlier in the thread (though they seem to have the same dimensions - http://www.aavidthermalloy.com/cgi-bin/stdisp_print.pl?Pnum=575002b00000g). So maybe the real issue is that I'm not exactly sure how to solder the heat sinks in, given the non-matching shapes and the large gaps where the sinks' legs don't fill the large pads for them (plus I can barely get mine to just fit into the pads at all).
wooster wrote: |
Good point - thanks! |
numbertalk
Posted: Wed Aug 13, 2008 12:23 pm Post subject:
Found some 6-32 x 3/8 nuts and bolts and they're perfect.
Could someone help me with installing the heat sinks? Should the legs fit all the way into the pads for each one? I'm guessing not because my heat sinks would get in the way of nearby outlying components if they were to each sit flush on the board (they each extend a bit into the board beyond the yellow "footprint" for them). This could mean I have the slightly wrong sized sinks but they seem to match the Reichelt ones exactly - I compared the data sheets and someone else on this thread also mentioned using the ones I got. However, I went ahead and ordered the ones Wooster said were a perfect fit for him, but if anyone wouldn't mind providing some details regarding securing and soldering the sinks to the board that would be great.
Thanks. |
wooster
Posted: Thu Aug 14, 2008 1:13 pm Post subject:
If you ordered the ones I used, then I would just wait until they come. They will fit the footprint and holes nice and snug. Otherwise you would probably have to saw off the tabs that go into the PCB or turn the heatsink upside down, and just rely on it being screwed into the transistor.
In either case I don't think you should solder the heatsink. I'm not sure it is possible. I tried and I couldn't get the solder to take to the heatsink. It could be the finish, or maybe the heatsink was doing its job and wicking heat away from the iron, not allowing the tabs to get hot enough. If it did get hot enough it would probably be dangerous for the transistor, because it could take a long time to cool down. The screw should be enough. |
Joined: Apr 03, 2004 Posts: 24461 Location: The Netherlands, Enschede
Audio files: 297
Posted: Thu Aug 14, 2008 1:17 pm Post subject:
Usually heatsinks are made of aluminum which can't be soldered ... well ... it's nearly impossible and it needs special solder. _________________ Jan
jhaible
Posted: Fri Aug 15, 2008 9:34 am Post subject:
Blue Hell wrote: | Usually heatsinks are made of aluminum which can't be soldered ... well ... it's nearly impossible and it needs special solder. |
Right, but the ones I have in my BOM (http://www.jhaible.heim.at/compact_clone/jh_krautrock_phaser_bom.pdf) *can* be soldered in. That's why I chose them in the first place.
But, when I tried to buy them for my first 2008-prototype, they were sold out and I bought the same form, but black and un-solderable instead.
Both work all right: The BOM-specified ones you can solder in; the black ones are put thru the holes and then what sticks on the solder side is twisted with a pincer, and also keeps in place.
numbertalk
Posted: Sun Aug 17, 2008 8:22 am Post subject:
Thanks for all the info. Wooster, got those heat sinks and you're right, they fit perfectly.
Another question - what exactly do the Rate and Amount inputs expect? I see that Bill & Will put "no cv!" on their panel, so these don't take CV, right? So are these for an expression pedal, something like the Moog EP-2? |
jhaible
Posted: Sun Aug 17, 2008 9:49 am Post subject:
numbertalk wrote: | Thanks for all the info. Wooster, got those heat sinks and you're right, they fit perfectly.
For a pedal that has a potentiometer inside, and a TRS jack, with the following wiring:
ccw end - sleeve
cw end - ring
wiper - tip
I think many pedals are wired like this.
(Yamaha pedals are *not* - they have ring and tip swapped.)
You have to try a pedal to see if it does what you want it to do.
The pot value, active angle (what part of the potentiometer's full range is actually used in the pedal construction) all have an influence on the response of the pedal.
numbertalk
Posted: Sun Aug 17, 2008 2:33 pm Post subject:
Another question - I'm not 100% clear on how to wire up the Manual DPST. It looks like for 1 of the set of poles, one pole goes to pin 1 of Manual and the other pole goes to pin 2. Then for the other 2 poles, those are wired together and then both wired to pin 3 of Manual, which is wired to ground - is that right? Seems logically correct to me but wanted to make sure.
jhaible wrote: | numbertalk wrote: | Thanks for all the info. Wooster, got those heat sinks and you're right, they fit perfectly.
ccw end - sleeve
cw end - ring
wiper - tip
JH. |
jhaible
Posted: Sun Aug 17, 2008 4:19 pm Post subject:
numbertalk wrote: | Thanks!
http://www.jhaible.heim.at/compact_clone/jh_krautrock_phaser_sch.pdf
Manual mode: Both R14 and R28 are connected to GND.
LFO mode: Neither R14 nor R28 are connected to GND.
