ian-s
Joined: Apr 01, 2004 Posts: 2669 Location: Auckland, New Zealand
Audio files: 42
G2 patch files: 626
Posted: Tue Jul 20, 2004 11:59 pm Post subject:
Mini Voyager |
What a monster of a monosynth!
I was curious about the dual filter configuration of the voyager so I set about reproducing it, based on info on the net. When complete, I decided to try the continuously variable wave shapers. Then, what the hell, why not do the whole damn thing?
The dual filters
These operate in two modes, serial LP->HP (for a variable width, band-pass response) and parallel LP. A Spacing control allows for adjusting the difference between the two filter frequencies. In the first mode, resonance only effects the LP section. The second mode applies each filter to a separate output.
The variable wave shapers.
Not content with the usual square-pulse shaping, or even the less common tri-saw shaping, the Voyager has gone for continuos tri-saw-square-pulse. Sorry Bob, I don't think this was a great idea but I suppose it saves on panel controls. I have reproduced it by using a pair of shape oscillators per VCO along with a lot of modules to set both shape controls and cross-fade at the right time. All very expensive and contributes little to the sound character, feel free to replace with a single shapeosc for a (much)leaner patch.
Modulation Bus X 2
This is a cut back version of the original, using the VCO3 wave as an LFO blows out the DSP usage (changes everything to audio rate). As a compromise, I have included a second LFO that can track the keyboard and go well into the audio range. No shaping but you can do that with morphs if required.
When it comes down to it, no matter how many modulation features Rudi adds to the Voyagers firmware, it will always fall short of the completely open ended G2.
Feedback is very welcome from anyone who owns or has played with the real thing. I don't think any have made it down here yet.
Description: |
Download |
Filename: |
vOYAGER1.pch2 |
Filesize: |
5.78 KB |
Downloaded: |
2561 Time(s) |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Wed Jul 21, 2004 2:28 pm Post subject:
I forgot to mention that the downloadable Voyager pdf manual has a good generic synthesis basics section. It reads like it was written in 1971 and assumes no prior knowledge. Learning synthesis by finding what every knob or button does may work for simple hard wired synthesisers. But to get the best from a modular, you should be familiar with certain basic principles (like voltage control) which make the whole confusing mess make sense. |
Joined: Jan 31, 2003 Posts: 18195 Location: Durham, NC
Audio files: 211
Posted: Wed Jul 21, 2004 3:22 pm Post subject:
That dual filter is similar to the original Moog Modular system. There was a high-pass and a low-pass filter, and a filter coupler module. This coupler provided band-pass and band-reject. The band with was voltage contolled as was the center frequency. |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Wed Jul 21, 2004 9:37 pm Post subject:
The Voyager configuration is sort of spoiled by designing it down to a single switch. Just providing two switches (serial/parallel, LP/HP for filter2) would have allowed for the notch mode you mentioned.
This implementation actually uses both filters in low pass mode, a converter on the output of filter 2 creates a simultaneous high pass response (using the subtract output from input technique). This is because the response needed to be switched along with the re-routing, by a single button. I could have used midi to do that but it is slot dependent. The switching was so complicated I had to write out a block diagram . A lot of work just to effectively constrain the functionality to match a hardware synthesiser.
It is possible to modulate the 'spacing' with a control signal. Currently that signal is just connected to a constant knob.
Just realised that this patch and the other emulations would require a fare amount of work for engine users, having the relevant controls assigned to the G2 panel makes a lot of difference. |
mother misty
Joined: May 13, 2004 Posts: 681 Location: Ghent / Belgium
G2 patch files: 130
Posted: Wed Jan 26, 2005 5:51 am Post subject:
Indeed.... what a monster!!
This one still scores pretty high in my G2-Top 10
(eh... maybe we should have a G2-patch top 10!
I've used it several times the last months. It can handle a broad range of sounds, but the reason why I like this one so much is because it can produce extremely raw & evil sounds (if you play around with the routings on page B2)
It's always my first choice if I'm looking for a monosynth,
for this wonderfull patch Ian!
(maybe a bit late, but I've had to say it |
cebec
G2 patch files: 31
Posted: Wed Jan 26, 2005 9:01 am Post subject:
well, i hadn't seen this patch at all, so thanks for pointing it out! |
tranzash
Posted: Wed Jan 26, 2005 6:46 pm Post subject:
What a great and phat patch |
Rare Bird Productions
Joined: Feb 26, 2005 Posts: 38 Location: Rijswijk - The Netherlands
G2 patch files: 6
Posted: Sun Mar 20, 2005 1:00 pm Post subject:
Like the patch, but there are so many modules involved in it, I hardly understand what they are all doing. |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Sun Mar 20, 2005 1:44 pm Post subject:
Rare Bird Productions wrote: | Like the patch, but there are so many modules involved in it, I hardly understand what they are all doing. |
Its been a while since I posted this, the bulk of the extra modules are the wave shapers, three identical columns 2,3,4. All they do is allow a single knob (or CV) to smoothly transition from Triangle - saw - square - pulse.
I have played the real thing since and I think the Voyager morphs from saw to square, rather than cross fade. If someone owns one, perhaps they could post a short wav of just one osc (filters open max) having its shape swept slowly.
I think I could probably make a few more optimisations with what I've learned over the last year as well . |
