Posted: Mon Sep 01, 2008 4:30 am Post subject:
Ian Fritz Sawtooth VCO Subject description: just a few short questions... |
hello ian, hello all,
looking at your schematic of the sawtooth VCO i see a 237K resistor (R6) at the summing node of the control voltages going to ground.
what is this resistor for? when i use a 1k termistor, will i have to lower this value as well?
you use a LM329 as voltage reference. if i wanted to use a say 5V reference, what should be changed? the 33K resistor? or said things different: why 6.9V? how has this value been calculated? _________________
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids) / facebook (news) Last edited by fonik on Thu Sep 04, 2008 12:49 am; edited 1 time in total |
frijitz
Audio files: 54
Posted: Mon Sep 01, 2008 12:36 pm Post subject:
Re: Ian Fritz Sawtooth VCO Subject description: just two short questions... |
| fonik wrote: | | looking at your schematic of the sawtooth VCO i see a 237K resistor (R6) at the summing node of the control voltages going to ground. |
Ummm ... actually it's going to the -6.9 V supply. It sets the overall range.
| Quote: | | when i use a 1k termistor, will i have to lower this value as well? |
Could you clarify that? You are using 1 k for the feedback resistor and 50 k for the 1 V/Oct input? If so, then you also need to halve all the other input resistors (R2, 4, 6, 7, 9).
| Quote: | | you use a LM329 as voltage reference. if i wanted to use a say 5V reference, what should be changed? |
You need to scale all the resistors that are supplying current by a factor of 5/6.9. These are R2, 6, 15. You need to make R21,2 provide 4 V, e.g., R21 = 22k, R22 = 100k.
| Quote: | | or said things different: why 6.9V? |
The LM329 is inexpensive and used to be available in a premium grade (but no longer). I now use 5 V subregulators.
I'm actually right now working on upgrading this design again. Several people have indicated interest in having a barebones saw vco (no waveshapers) for stacking, for polysynths, or for using with external waveshapers. So boards may be made available if there is enough interest.
Ian |
Posted: Mon Sep 01, 2008 1:27 pm Post subject:
| frijitz wrote: | | fonik wrote: | | looking at your schematic of the sawtooth VCO i see a 237K resistor (R6) at the summing node of the control voltages going to ground. |
Ummm ... actually it's going to the -6.9 V supply. It sets the overall range.? |
ahh, i didn't se that. mixed the symbols.
| Quote: | | Quote: | | when i use a 1k termistor, will i have to lower this value as well? |
Could you clarify that? You are using 1 k for the feedback resistor and 50 k for the 1 V/Oct input? If so, then you also need to halve all the other input resistors (R2, 4, 6, 7, 9).? |
yep, 1k in the feedback path and okeydokey
| Quote: | | Quote: | | you use a LM329 as voltage reference. if i wanted to use a say 5V reference, what should be changed? |
You need to scale all the resistors that are supplying current by a factor of 5/6.9. These are R2, 6, 15. You need to make R21,2 provide 4 V, e.g., R21 = 22k, R22 = 100k.? |
okay, i will take a look at the schematic again.
| Quote: | | Quote: | | or said things different: why 6.9V? |
The LM329 is inexpensive and used to be available in a premium grade (but no longer). I now use 5 V subregulators.? |
i had a hard time sourcing the LM329/129 but eventually found it (minimum order of 10 pieces, so i could build some VCOs)
| Quote: | I'm actually right now working on upgrading this design again. Several people have indicated interest in having a barebones saw vco (no waveshapers) for stacking, for polysynths, or for using with external waveshapers. So boards may be made available if there is enough interest.
Ian |
huh, i am still planning my keyboard synth. i still have this EFM wildcat PCB but finally decided not to use it
so i started planning a synth built it from various circuits. i decided to use you VCO. furthermore i had the feeling that i am in need of some reliable, top notch VCOs for my modular, VCOs i can rely on. nevertheless i will etch my own PCBs, though. i want to use PCB mounted controls as much as possible.
however thank you very much for your patience and the clear answers, ian. very appreciated. _________________
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids) / facebook (news) |
