SN Voice connector wiring
Page 1 of 1 [6 Posts]
69charge
PostPosted: Mon Oct 27, 2008 2:19 pm    Post subject: SN Voice connector wiring Reply with quote  Mark this post and the followings unread
Scott and Thomas,
I love your SN Voice PCB and I am building up the first of two boards now. I didn't receive any paper instructions but I found most of the documentation here on the web. Is there a place that shows the interface wiring from the panel to the Molex connectors on the board? I can't seem to find it. Also, I'm not sure exactly what component belongs in U5 as it is not listed in the parts list. I suspect it may be a 7805 +5VDC regulator but I haven't reverse engineered the traces to be sure. What is the power scheme / options for the board? The drawings are not clear in that regard. I will have both 5VDC and +- 15 VDC available in my rack design. Any help will be greatlt appreciated.
Bill Barnes
Appliancide*
PostPosted: Mon Oct 27, 2008 7:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
The post above this one that says "SN boards shipping now" or something like that has a link to the full documentation. U5 is a 78L05, it's mentioned in the notes under the BOM.
69charge
PostPosted: Tue Oct 28, 2008 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed Thanks! I don't know how I missed the panel wiring page.
Bill
Appliancide*
PostPosted: Sun Nov 09, 2008 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, now I have a question. What are all of the little unmarked holes on the pcb for?
Dan Lavin
Audio files: 21
PostPosted: Sun Nov 09, 2008 7:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm guessing you're referring to the "vias." They are plated thru-holes that connect the top traces to the bottom traces on the pcb.
Appliancide*
PostPosted: Mon Nov 10, 2008 7:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool. I just wanted to make sure I wasn't missing out on any secret functions, though I couldn't imagine the module that doing much more! I can't wait to play with this!
