Posted: Tue Jan 28, 2014 11:11 am Post subject:
Alien Spoonbending Subject description: improv with zero input alienator and other DIY devices |
something I recorded last nite. I used the Alienator as a zero input mixing device, but I also had the simple sampler recording it's output and feeding
it back to the input (not sure if this still counts as zero input, although it's basically just a long delay ) I hooked up the Lun-A-Key to the Soundbender,
which is a modulator based on a XR2206 chip, and used the modulation source of that (triangle wave) to create a droning sound. This was then fed
into a weird UAA180 based waveshaper I breadboarded (a bit similar to the 5 pulser) and there was some extra (chorus + reverb) effects added to
the output of that. The waveshaper was modulated by a random voltage generator with an extra capacitor added to the CV input to create a gliding
effect. I also hooked up my RGB shroom synth for some pingy sounds. The Lun-A-Key was controlled by midi data I received from Blue Hell, which is
(partially) generated by the chat, and I used that to control the simple sampler and delay time on the alienator aswell.
I will post some longer bits later but here's a short section that also included some samples/loops.
Description: |
Filesize: |
55.93 KB |
Viewed: |
835 Time(s) |
Description: |
"although his name is untranslatable to any Earth language, it would sound something like Zontar" |
 Download (listen) |
Filename: |
PHOBoS - Alien Spoonbending (Zontar radio mix).mp3 |
Filesize: |
12.81 MB |
Downloaded: |
3524 Time(s) |
SoundCloud BandCamp MixCloud Stickney Synthyards Captain Collider Twitch YouTube Last edited by PHOBoS on Thu Jan 30, 2014 12:55 pm; edited 1 time in total |
Joined: Mar 28, 2006 Posts: 1451 Location: Kansas City, Mo USA
Posted: Fri Jan 31, 2014 10:50 pm Post subject:
That is really awesome. The Zontar mix vaguely reminds me of some droney bits from My Life in the Bush of Ghosts, though maybe that's just the distorted vocal samples  |
