Formant Oscillator RND?
Page 1 of 1 [3 Posts]
Oortone
PostPosted: Mon Apr 25, 2016 6:22 am    Post subject: Formant Oscillator RND?
Subject description: What's special about the RND-timbre
In the Formant Oscillator there are 127 timbres + RND.
What's the use of this RND?
It seems like it will pick a random timbre (I guess it's one of the 127 others) each time it's selected but there's no way to trig this random selection from the outside world, like when a key is pressed. At least not with a lot of complicated logic.
It's very easy to randomly select the other waveforms using the Clock Random Generator connected to the timbre modulation input of the Formant Oscillator so I see absolutely no use for this option.
Any ideas?
Moody33
G2 patch files: 16
PostPosted: Sat Apr 30, 2016 2:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Rdm mode set a random timbre value for each voice in a patch when loading this patch . Each voice have it's own timbre which is not rdm on key trigger. If you want to trigger a new random value on each key press, you need to add a clockGen module as show in the picture below.
[/img]
 Filesize:  43.04 KB
 Viewed:  2506 Time(s)
Oortone
PostPosted: Mon May 02, 2016 5:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, that of course makes it usable.
How did you find the information, it's not in the manual?
