Marjan Urekar's BUCHLA 194 Fixed Filter
Page 1 of 1 [17 Posts]
funkyfarm
PostPosted: Tue Feb 20, 2007 2:22 pm    Post subject: Marjan Urekar's BUCHLA 194 Fixed Filter
Subject description: Splitting input signal into four bands
Marjan wrote:
Splits input signal into four bands
under 200/200-900/900-4000/4000 Hz,
using just few transistors.
http://members.tripod.com/urekarm/synth/download.html
Has anyone have a attempt with this marjan urekar's version ?
Schematic with BC550/560
The four 1uF capacitors at each output have to be unpolarized, no ?
for both positive and negative "phases" of the audio signal to pass through ?
Am I wrong ?
I see them as 1000nF polyester caps...
Scott Stites
Audio files: 96
PostPosted: Tue Feb 20, 2007 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, they can be polarized. You just connect the positive end at the point that the signal will always generally be more positive.
Back in our Buchla phase, Jeff Pontius built a couple of these and gave me one - forgot I had it! Thanks for the reminder, I'll have to dig it up.
Scott
funkyfarm
PostPosted: Wed Feb 21, 2007 6:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep !
About the caps, I hadn't noticed the circuit was supplied only by +15V and Ground (if there's a link in between...)
I was thinking about adding a mixer, because 4 outputs is a lot ! (each with its filter, VCA, etc...)
There's only one INPUT, and OUTPUTS are :
Low : under 200 Hz
Lo Mid : 200-900 Hz
Hi Mid : 900-4000 Hz
Hi : above 4000 Hz
So,
mixing Low and LoMid (normalized) at Low output
(if nothing connected into LoMid socket)
mixing Hi and HiMid (normalized) at Hi output
(if nothing connected into HiMid socket)
then the signal would be splitted in two Hi/Lo bands...
maybe adding an extra "Medium" socket, fed by a mix of the LoMid and HiMid outputs...
Or maybe it would be clever to customize the circuit to only three outputs...Wink
with the same bandwidth...
What would be the two best cutoff frequencies ?
I guess that we can say, with no shame, that the maths would surely be something like f=1/T=RC....somehow...somewhere, no ? Laughing
funkyfarm
PostPosted: Mon Mar 31, 2008 12:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you marjan !
I've perfboarded one.
The schematic is all correct, included all capacitors polarization.
It works great, this design has lot of gain ! (Q boosted ?)
I still think a dual mixer would be great.
Total spectrum would be split on two sockets (under 900Hz, above 900Hz)
This is great for stereo effect...
Otherwise, three bands could be enough I guess.
I wish I kwen how to change cap for customizing bands...
 Filesize:  4.06 KB
 Viewed:  18045 Time(s)
vtl5c3
PostPosted: Mon Mar 31, 2008 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I built one of those a while ago. The original CBS schematic has an error on it. Not sure about Marjan's though.
mono-poly
PostPosted: Mon Mar 31, 2008 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah i wann build one of these.
Who is coming up with some other 100 series stuff?
Smile
Scott Stites
Audio files: 96
PostPosted: Mon Mar 31, 2008 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool
My Site
funkyfarm
PostPosted: Tue Apr 01, 2008 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
The original CBS schematic is on-line ?
now you can be Very Happy
(i'll throw some stereo samples with my oncoming dual vactrol cross fader...)
funkyfarm
PostPosted: Tue Apr 01, 2008 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Smile
Definitely.
Buchla clones have changed my patch.
CJ Miller
PostPosted: Fri Apr 04, 2008 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Smile
Nearly all of the Buchla schematics I have I downloaded from Magnus Danielson's pages, but I can't find a link now. About half of the total series 100 modules, and a few 200. The 100 modules look much simpler, easier for me to understand and build. But the 200 modules look much more interesting, musically. I can hardly understand the functionality of synth circuits at all, and Buchla's genius gives me a headache when I am trying to figure his stuff out, even just to clone! Another factor which has kept me from experimenting with Buchla circuits is that it seems they don't use the same 10v peak-to-peak voltages as other modules. I am scared to even breadboard the stuff now, maybe when I am more experienced.
I heard that years ago, somebody published a book in Japan on cloning the 100 series Buchla modules! It had schematics, PCB layouts, and other info. Mark Verbos confirmed that he has seen this book with his own eyes. This would be the ultimate resource if you want to clone 100 series modules, but it is very scarce.
If anybody knows more about this book, please do let us know!
Part of my problem is that I am attracted to many of Buchla's more sophisticated circuits. Maybe somebody with the skills should try making a run of MARF PCBs?? Razz
vtl5c3
PostPosted: Fri Apr 04, 2008 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I have a photocopy of the japanese book. About half the circuits are Buchla 100 based, the other Moog modular. The author did make changes to some of the circuits, plus they use Japanese silicon instead of US or european parts. I've scanned some of Buchla 100 stuff in and will be glad to forward to other users via PM. I don't think that the 194 is included.
Coriolis
PostPosted: Fri Apr 04, 2008 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is Magnus' Buchla page - 100 series at the top, and 200 series further down.
http://rubidium.dyndns.org/~magnus/synths/companies/buchla/
Doesn't do me much good tho, as I find the 200 series schems almost unreadable. Does anyone know who drew these? They're original I think?
I agree the 100 series doesn't look so interesting compared to the stuff were building in this forum today. But back then it was a different matter, of course. They seem to be completely made with discretes also. I wouldn't bother building these I think, except perhaps the 194.
C
mono-poly
PostPosted: Fri Apr 04, 2008 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
But the best Morton albums are done with the 100 series Smile
ericcoleridge
PostPosted: Fri Apr 04, 2008 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was recently asking around, to various DIY people on the web, about building a Buchla style touch-plate interface. One of the people I e-mailed told me he had used this Japanese clone book for it's PCB layouts of the touchplate keyboard and circuitry. He's looking for it for me.
I know there is a good article in Synapse for a similar touch controller, but I thought it would be cool to have the original Buchla touchplate artwork.
Coriolis
PostPosted: Sat Apr 05, 2008 2:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Eric, if you get hold of that, I'd be very interested too. I may try to build that synapse circuit at some point, but it would be great to see the Buchla as well..
C
6079smith
PostPosted: Sat Apr 05, 2008 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
That book you guys are talking about sounds really interesting, if just for academic purposes...
Back on topic, I built a dual version of this not so long ago on perfboard - directly from the schematic left to right, so it fills quite a bit of real estate. It does exactly what it says on the box. It's nice how something so simple can have so much sonic usefulness...
vtl5c3
PostPosted: Sat Apr 05, 2008 7:21 am    Post subject: Reply with quote  Mark this post and the followings unread
One of the Stokes brothers, by any chance?
