Fonik LPG: modifying it ( with more CV inputs and others )
Page 1 of 1 [25 Posts]
Funky40
G2 patch files: 5
PostPosted: Sun Mar 30, 2008 10:36 am    Post subject: Fonik LPG: modifying it ( with more CV inputs and others )
Subject description: i need some help
hi, i need some help to modify the Fonik LPG.
how can i make more CV inputs ?
The regular CV input has not only an input Resistor,
it has also a crossconnection to the Offsetpot with a Resistor and a cap. ( R4 , C5 )
so i think it is not enough to just add another CV input with a inputresistor.
the schematic: ( side 2 )
http://modular.fonik.de/pdf/low%20pass%20gate.pdf
i have a dual Fonik LPG running, and i'm often miss more CV inputs.
got now new boards and like to modify it with some cludging
PostPosted: Mon Mar 31, 2008 1:06 am    Post subject: Reply with quote  Mark this post and the followings unread
if i ever would built one again i'd tried to leave off R5, C5. as you can see from the redrawn schematics i just did a layout for p grenaders version of this LPG. in fact i don't know what R5, C5 is actually used for... any idea anyone?
Funky40
G2 patch files: 5
PostPosted: Mon Mar 31, 2008 4:14 am    Post subject: Reply with quote  Mark this post and the followings unread
good Info fonik ! thanks !
so i will try just to sum another input with input resistor
a.b.o.z.
G2 patch files: 4
PostPosted: Mon Mar 31, 2008 5:26 am    Post subject:   Reply with quote  Mark this post and the followings unread
what is low pass gate and what does it do?
sneakthief
PostPosted: Mon Mar 31, 2008 7:10 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik - did you ever try the resonance option?
a.b.o.z. - it's the vactrol-based filter/gate that gives the buchla it's infamous plucked / "banjo sounds" Very Happy
more info & samples:
http://www.cyndustries.com/modules_quadgate.cfm
http://www.doepfer.de/a1012.htm
Sneak-Thief - raw electrofunk
PostPosted: Mon Mar 31, 2008 11:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
not yet. i just incorporated mark verbos post on this topic to the documentation.
loss1234
PostPosted: Tue Apr 01, 2008 4:13 am    Post subject: Reply with quote  Mark this post and the followings unread
im confused
it looks like your old docs have 2 vactrols in the schematic, while the new doc has only one.
which one is correct? or am i reading this wrong
thanks
sneakthief
PostPosted: Tue Apr 01, 2008 4:27 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks fonik - i thought so.
loss1234 - yes, you're reading it wrong. schematics often "visually" split up the single vactrol into individual LED and resistor components.
loss1234
PostPosted: Tue Apr 01, 2008 4:43 am    Post subject: Reply with quote  Mark this post and the followings unread
no i am pretty sure the old schematic shows two-i think i figured out the difference though. the old one shows two vclt5's and the new one shows one vtcl3/5
thanks
sneakthief
PostPosted: Tue Apr 01, 2008 4:48 am    Post subject: Reply with quote  Mark this post and the followings unread
oh the "old" schematic - yes, you're right: it does show V1 & V2 as an ersatz vtl5c3/2
PostPosted: Tue Apr 01, 2008 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
one VTL5C3/2 instead of two VTL5C3 is much more economic...
Funky40
G2 patch files: 5
PostPosted: Tue Apr 01, 2008 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I gonna build one LPG for a Friend ( ACA ), he is running it at 12V .
Does i have to change something ? ( i build again the old one )
I assume that it will have less Gain on 12V, whats not so good as it anyway has not too much
i don't know whats to change.
btw.:
i built my (old) Fonik LPGs also with the dual Vactrol VTL5C3/2
Fonik has made a wiring diagramm
krisp14u
PostPosted: Tue Apr 01, 2008 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
I built one up with the resonance option and can confirm that the feed back loop dose indeed work
I got a better result with a 50k log pot for the res and I also reversed the pot so it gave more oscillation the more CW it was turned
Oscillates like hell on hi res setting but well worth the extra parts needed
Paul D
Paul Darlow
www.krisp1.com
PostPosted: Wed Apr 02, 2008 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
do you have a breadboard? my first guess: try increasing the value of R14 (resistor in the feedbackpath of U1).
Funky40
G2 patch files: 5
PostPosted: Tue Apr 08, 2008 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
here is the schematic fonik has drawn,
which shows how to put one dual Vactrrol ( VTL3C3/2 ) into the old version of the fonik LPG
Funky40
G2 patch files: 5
PostPosted: Wed May 28, 2008 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
To replace R14 with a Trimmer, what Value would be good, 20K ?
and with what other parts of the Circuit is R14 related in relation to the Outputgain ?
PostPosted: Wed May 28, 2008 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
that's what i'd do. start with trimmer set to 10k
the vactrol itself, i'd said!?
Funky40
G2 patch files: 5
PostPosted: Wed May 28, 2008 5:36 am    Post subject: Reply with quote  Mark this post and the followings unread
hmmm, i don't understand trimmers Embarassed
what Value should i solder in ?
PostPosted: Wed May 28, 2008 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry. i'll try to be more clear.
use a 20k trimmer and wire it as variable resistor: solder wiper and one pin together to the output of the opamp (U1, pin7), the left pin to the inverting input (U1, pin6). set the trimmer in a way so you measure about 10k between the opamps output and inverting input.
alternativily you could use alligator clips and try a 4.7k in parallel to R14 and see what happens first.
Funky40
G2 patch files: 5
PostPosted: Wed May 28, 2008 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, i will test it out.
I have a board here which can take also a Trimmer for R14.
The Board is allready populated, exept R14.
I'm just waiting for some stuff to make Faceplates.
thanks alot !
the Fonik LPG is allways the most important module in my System for my sound.
Funky40
G2 patch files: 5
PostPosted: Fri May 30, 2008 2:29 am    Post subject: Reply with quote  Mark this post and the followings unread
hmmm, my board is vice versa.
Wiper is connected to the Pin that goes to the inverting input of the OP amp.
Does this not work ?
PostPosted: Fri May 30, 2008 2:34 am    Post subject: Reply with quote  Mark this post and the followings unread
doesn't matter at all (that's only changing the turn direction of the trimmer). the wiper has to be connected to one of the left pins, that's all (like T1 on the schematic).
Funky40
G2 patch files: 5
PostPosted: Fri May 30, 2008 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, thanks
CJ Miller
PostPosted: Fri Jun 06, 2008 8:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Regarding the choice of 2x single vactrol vs 1x dual vactrol - I read on the SDIY list a post from Peter Grenader who said that he by far prefers using two singles. Dual for VCA type use and reduced noise, but two singles for filtering and plucked sounds. He said he's built hundreds of these circuits and tinkered with them quite a bit over the years, so I trust his opinion here.
Meanwhile, my beautiful LPG boards are lost in the basement here! I have been looking for them for weeks. When my Klee boards arrived I collected them and my LPG together and decided to put them in some special place so nothing would happen to them. Now only if I could remember where!
Funky40
G2 patch files: 5
PostPosted: Sat Jun 07, 2008 8:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
CJ Miller wrote:
Regarding the choice of 2x single vactrol vs 1x dual vactrol - I read on the SDIY list a post from Peter Grenader who said that he by far prefers using two singles. Dual for VCA type use and reduced noise, but two singles for filtering and plucked sounds. He said he's built hundreds of these circuits and tinkered with them quite a bit over the years, so I trust his opinion here.!
very interesting, thank you for posting it !
In the meantime i recognised, that on my dual Fonik LPG, the behave of both units is really different.
One is perfect, the other has not that plucked sound with very short envelopes. I've built both with dual Vactrols and use them most in the both mode.
LOL ( sorry), i had the very same Problem with my 5 Pulser Boards, but i found them one Day in a bag i putted into another bag.
they must be somewhere Wink , good luck
