BUCHLA 291e / new AMPLITUDE feature
Page 1 of 1 [8 Posts]
funkyfarm
PostPosted: Sat Dec 06, 2008 7:27 am    Post subject: BUCHLA 291e / new AMPLITUDE feature Reply with quote  Mark this post and the followings unread
The 291e Triple Morphing Filter consists of three voltage controlled filters operating independently or in parallel.
The amplitude, center frequency, and bandwidth of each filter may be independently voltage controlled. Each may be modulated with externally applied signals.
is anyone have a clue to understand how this new AMPLITUDE feature is implemented ?
VCA on signal input ?
VCA on signal output ?
vactrol vca style (292) ?
Is it here to lower input signal when RESO/BW settings start to get dangerous ?
ff
http://www.buchla.com/images/modules/200e_291e.jpg
cbm
PostPosted: Sat Dec 06, 2008 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I believe it's a vactrol on the output. It only effects the mix out (not the individual filter outs), so it can't be on the input of the filter.
Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job)
funkyfarm
PostPosted: Sun Dec 07, 2008 9:07 am    Post subject:
Subject description: Crosstalk: Don Buchla replies...
SOS quotes :
As its name suggests, the 291e contains three digitally controlled analogue band-pass filters, with control over centre frequency, amplitude and bandwidth, the last two of which imitate the resonance of traditional band-pass filters, but without self-oscillation
Since yesterday, I was about to think Don's AMPLITUDE to be what Scott Stites called Resonance.
http://mypeoplepc.com/members/scottnoanh/sitebuildercontent/sitebuilderfiles/291%20.jpg
Cool
However, Don had a lot of (nasty) things to tell about this article... Laughing
funkyfarm
PostPosted: Sun Dec 07, 2008 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I am such an ignorant.
I had to wander around Music Easel and youtube to realise that 259's TIMBRE is (also surely) through zero FM.
The complex osc triangle wave is amplitude modulated by the mod osc, then the timbre control (through zero FM) on the complex osc is raised around the 7 sec mark. At about 20 secs the switch is flipped to change from AM to FM on the mod osc., varying the frequency until it's back to triangle, then sine.
http://www.youtube.com/watch?v=c6NVkxLX6Gs&NR=1
cbm
PostPosted: Sun Dec 07, 2008 10:52 am    Post subject:
[quote="funkyfarm"]SOS quotes :
SOS is wrong here. It really is just amplitude of the filter into the mix. It allows you to set the level of each filter, for each step of the mini-marf.
It's not FM. It's in the general class of non-linear transform that some call a wave folder. The Timbre section of the Music Easel, the 259 and the 261e are all fairly similar.
The Serge Wave Multiplier is another example of a wave folder.
- C
Chris Muir
funkyfarm
PostPosted: Mon Dec 08, 2008 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am such ignorant. Very Happy
Thank you for these real precious infos.
Now I guess that Cynthia's Zeroscillator is in no way a 259 style sound generator ? (i think i've read that somewhere online Cool )
I'd better stop googling.
ff
cbm
PostPosted: Mon Dec 08, 2008 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, the Zeroscillator is not that similar to the 259. The Zeroscillator specializes in FM, which is great for what it is; I have one on order.
The 259, with it's Timbre section, is in its own world, much of which it shares with the current 261e, and to some extent with the Music Easel.
Chris Muir
funkyfarm
PostPosted: Fri Dec 12, 2008 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Many thanks for your precisions and for sharing experience.
ff
