Buchla 266 MM5837 Digital Noise IC
Page 1 of 1 [12 Posts]
funkyfarm
PostPosted: Sun Jan 11, 2009 4:12 am    Post subject: Buchla 266 MM5837 Digital Noise IC
Subject description: groupbuy ?
Hi !
Buchla 266 MM5738 Digital Noise IC : pack of 10.
http://cgi.ebay.fr/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=290265645199
Hi !
This seller don't ship to France.
I live in France.
I'm sad.
ff
PS : 70 pieces left today. It says Brand new not pulls or counterfeits. but it seems to be pulled...
[edit]I've edited the title ; remplacing MM5738 with correct MM5837 Very Happy [/url]
e-grad
PostPosted: Sun Jan 11, 2009 4:24 am    Post subject: Reply with quote  Mark this post and the followings unread
At least by now they state
Authentic socket pulls now increasingly hard to find!
Accord. to Analogue Heaven technologytransplant and the well reputed chipforbrains are the same.
Luka
PostPosted: Sun Jan 11, 2009 4:49 am    Post subject: Reply with quote  Mark this post and the followings unread
hey i can grab a 10pack and send you some man
happy to split it in half if you wish
problemchild
melbourne australia
funkyfarm
PostPosted: Mon Jan 12, 2009 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Coool !
I'm a little bit surprised and/or suspicious that no one here in Europe seem to be interested.
I'm back on Friday.
ff
Audio files: 297
PostPosted: Mon Jan 12, 2009 10:57 am    Post subject: Re: Buchla 266 MM5738 Digital Noise IC
Just for what it's worth ... there seems to be a mix up of a couple of things ...
The link points to a site advertizing MM5837N noise source for the poly moog, not for a buchla. The MM5738 seems to be a calculator chip, but note the digit swaps. Also http://www.musicsynthesizer.com/Buchla/source_of_uncertainty.htm (schematics for the buchla 266 source of uncertainty) doesn't list either of these chips in it's schematics ... it uses a traditional parallel out shift register for the random generator ... and it needs to be done that way to be able to get the 2^n and the n+1 outputs.
numbertalk
PostPosted: Mon Jan 12, 2009 11:03 am    Post subject: Re: Buchla 266 MM5738 Digital Noise IC
I believe he did mean an MM5837 from a Buchla SOU clone project by member vtl5c3:
http://electro-music.com/forum/download.php?id=15753
Audio files: 297
PostPosted: Mon Jan 12, 2009 11:07 am    Post subject: Re: Buchla 266 MM5738 Digital Noise IC
numbertalk wrote:
He did mean an MM5837 from a Buchla SOU clone project by member vtl5c3:
Ah ok, that clears it up then, thanks!
Was just wondering BTW what the chip would do exactly & got confused trying to look it up ... but got that sorted out now too Wink
mono-poly
PostPosted: Mon Jan 12, 2009 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
funkyfarm wrote:
Coool !
I'm back on Friday.
ff
Contact me i did order a batch of 10.
Peake
PostPosted: Mon Jan 12, 2009 6:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I cannot believe that the day has come when early digital noise is desirable...
KaDUNKacha...kaDUNKacha...KaDUNKacha...
etaoin
PostPosted: Tue Jan 13, 2009 1:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Indeed, the very chips Korg did a revision of the Mono/Poly for because they were so completely terrible (i.e. it has an audible repeat).
http://www.casia.org/modular/
funkyfarm
PostPosted: Fri Jan 16, 2009 2:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Here comes the day a 266 is desirable for everyone.
This is not a day, this is history. Smile
That's what digital noise are all about ?
I've understand Buchla random voltage sources to be drastically random, gently cyclic. either the noise source ?
Luka
PostPosted: Fri Jan 16, 2009 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
i dont think ill buy a set of these chips now
so if anyone has any spare please let me know
problemchild
melbourne australia
