<on air> Modulator ESP Adventures In Sound
Tips for touch plates using Copper Clad boards
Page 1 of 1 [12 Posts]
synthmonger
PostPosted: Thu Apr 16, 2009 10:55 am    Post subject: Tips for touch plates using Copper Clad boards
Subject description: to seal or not to seal? Or use an alternative to copper clad boards?
I'm starting my huge modular project and I want to use a touch plate similar to Buchla's as the main controller. I only have copper clad boards that I plan on etching a design out of which will also serve as the front as the front plate. It will consist of a few boards spanning probably 4U and 19' width.
The last thing I would want is for the copper to oxidize, then I thought sealing it would protect it but I'm not sure how it will effect sensing touch. Does anyone have experience with this sort of thing? Any tips will be greatly appreciated! Razz Razz Razz Razz
wetterberg
PostPosted: Sat Apr 18, 2009 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
did you read this yet?
http://www.cyndustries.com/synapse/synapse.cfm?pc=39&folder=jan1977&pic=26
- I guess none other than the master of the TKB would be the guy to take notes from, he suggests a "thin coat" of polyurethane or acrylic.
synthmonger
PostPosted: Sat Apr 18, 2009 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I did but I somehow overlooked that text. I blame coffee! Razz
Youtube!
modular demos!
Whacky tunes!
wetterberg
PostPosted: Sat Apr 18, 2009 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
no worries, hope to see that mega-modular come together quickly Smile
scriptstyle
PostPosted: Sat Apr 18, 2009 4:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'm working on some copper clad touch plates off the serge schematics. i'm wondering how to implement some type of velocity/surface area logic sensing circuit.
frijitz
Audio files: 54
PostPosted: Mon Apr 20, 2009 7:59 am    Post subject: Re: Tips for touch plates using Copper Clad boards
synthmonger wrote:
...The last thing I would want is for the copper to oxidize, then I thought sealing it would protect it but I'm not sure how it will effect sensing touch. Does anyone have experience with this sort of thing? Any tips will be greatly appreciated!
I have capacitive switches on one of my wind controllers. Acrylic or epoxy coatings wear through quite quickly. You start to see oxidation around the edges, then it spreads. I'm not sure if the coating has worn off or if there are just bad spots such as pinholes.
Actually I'm in the process of redoing them right now. I'm trying the starter kit from these folks:
http://www.everbritecoatings.com
They make it sound good anyway.
Ian
synthmonger
PostPosted: Mon Apr 20, 2009 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Ian! I'll have to try that out as well. Probably won't be for a while though with all my other projects. Please let me know how it works for you.
Youtube!
modular demos!
Whacky tunes!
scriptstyle
PostPosted: Mon Apr 20, 2009 9:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
would a pcb silicone aerosol such as http://www.mgchemicals.com/products/422a.html work? probally not because it insulates?
scriptstyle
PostPosted: Thu Apr 23, 2009 6:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
while shopping for capacitors for the tkb i noticed that the serge schematic has some less common values? for the 22pf 5% im thinking i need something fancy like this? http://mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMtLiKaZgV7flaUuJGyUMyGomM%2f1uVuG2R8%3d
also the 430pf is a very odd value. can that be replaced with a 470pf, and if so i was thinking mylar or poly? only the ceramics are labled. being as old as it is my guess everything is mylar?
scriptstyle
PostPosted: Wed Apr 29, 2009 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
looking more at the paia PDS design. im wondering how it stacks up to the serge TKB? the PDS has a much lower part count and one can implament pressure sensitivty with alittle more effort and minamal parts. on the other hand the lm3900 is a high gain op amp is there something importatnt of using a component like this over cmos? and last but not least if in fact the lm3900 is better for the job could touch pressure be implamented into the TKB with simple cmos?
CJ Miller
PostPosted: Mon May 11, 2009 9:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
The regular Serge (non-Synapse) TKB is a CMOS circuit. It uses a standard CMOS clock and a TTL 16-1 mux, combined with a 4516 sequencer. I am looking into redoing it with a CMOS mux and some other features, but it's got to wait for now.
ericcoleridge
PostPosted: Thu Jun 04, 2009 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just thought I'd post this in case anyone hasn't seen it. It's a capacitance polyphonic touch controller, called the Manta, for MIDI/USB. Apparently inspired by Buchla Touchplates, I believe he uses a laser cutter to etch PCBs for the actual touch surface:
http://snyderphonics.com/products.htm
 Filesize:  14.91 KB
 Viewed:  15327 Time(s)
