Does Buchla roll his own Vactrols now?
Ricko
Audio files: 27
PostPosted: Sun Jan 17, 2010 7:14 am    Post subject: Does Buchla roll his own Vactrols now? Reply with quote  Mark this post and the followings unread
Am I right in thinking that Buchla himself no longer uses manufactured Vactrols but rolls his own using red resistors and some photoresistor? See
http://www.flickr.com/photos/adeneko/3775716262/in/set-72157621777322235/
and
http://www.flickr.com/photos/adeneko/3775690982/in/set-72157621777322235/
Is this just a price issue?
Boogdish
PostPosted: Sun Jan 17, 2010 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
That definitely looks like LEDs pointed at LDRs.
It might just be a price issue, but it might also be an issue of needing a value for his LDR that he couldn't easily find in a prepackaged vactrol. Also, I noticed that the LED has some space between it and the LDR, perhaps he has experimented and found that he likes the sound better when it's not a perfect coupling and he does it for this reason.
I'm surprised there's no covering over them to keep ambient light from interfering. It would just take a little bit of shrink tubing.
cbm
PostPosted: Sun Jan 17, 2010 8:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
For the classic Low Pass Gate, e.g. 292e, there are still Perkins-Elmers Vactrols VTL5C3 used. In places where gain needs to be controlled, but the specific ringing characteristics associated with the VTL5C3 aren't required, there are home-grown vactrols used.
Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job)
xpander
PostPosted: Wed Apr 13, 2011 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
bumping an ancient thread, you missed the close-up photo from my buchla set:
snebenan
PostPosted: Thu Apr 14, 2011 4:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Comparing the Perkin Elmer datasheets and the specifications for photoresitors there is a major difference in range of resistance.
VTL5C3: 1,5 Ohm -> 30 kOhm; (10MOhm when OFF for 10sec)
Photo Cells usually are in many different ranges, but most seems to go from x k Ohm to 3x kOhm.
Example: 6k->18k, 24k-72k, 4k->12k etc.
So as I see it there is a major difference in the dynamic resistor range.
Anyone tried to do stuff with their own rolled "vactrols" and care to share the specs of the leds and ldr's used?
//s
