LFO Delay
Page 1 of 1 [22 Posts]
PostPosted: Mon Feb 19, 2007 4:36 am    Post subject: LFO Delay Reply with quote  Mark this post and the followings unread
Hi all,
Does anyone build this LFO delay with success ?
I just built it, with BC547/557 trannies and +15-15 powered, and it don't work at all...
I can see C2 1uF caps discharge on gate, but nothing after R2.
My LFO (initially +5/-5v) output voltage is stuck to +0,5/-0,5 but don't raise to +5/-5 when C2 is discharged..
Any idea ? Do I need to change R2 resistor value to fit with my power supply or BC557 properties ?
thanks !
andrewF
PostPosted: Mon Feb 19, 2007 8:02 am    Post subject: Reply with quote  Mark this post and the followings unread
This is one of Kunii San's (aka Masa 921), a master of minimal circuit design.
I built it a few years back, no probs (not that I remember )
I think it was meant to be an add-on for his LFO.
The transistors are nothing special -I've used C1815(npn) and A1015(pnp) for nearly every CGS circuit with no trouble or mods(other than different pinout). Also I used -15V with this.
The synth, it lives in, is in storage now so I can't get to it to check anything.
If you're sure all connections and orientations are good, I guess R2 is the place to start experimenting.
Masa921 is not much good at English but if you are stuck I can check with the guys at Japanese synth-diy for some hints.
I can't resist posting this pic - Masa921 microVCO, no chips just 5 transistors and 2 FETs, V/Hz and V/oct control and it sounds awesome, very meaty. Thats the whole cct in a blob of goop. He bought it to a diy meeting, hooked it up and started playing. everyone was pretty stunned by the quality (and the size)
funkyfarm
PostPosted: Mon Feb 19, 2007 8:33 am    Post subject: Re: LFO Delay Reply with quote  Mark this post and the followings unread
211 wrote:
Hi all,
This is a cheap design as it obviously doesn't reset your LFO waveform.
So, after delay time being elapsed, the LFO doesn't start from zero...
211
PostPosted: Mon Feb 19, 2007 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
This design is the same as MC202 LFO . I connected my LFO in the same way.. I checked trannies pinout with eagle before assembly..
Now, as andrewF has already built it, I m sure that design may works..
I probably missed something...
211
PostPosted: Mon Feb 19, 2007 3:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
that's ok, it works fine ! ( was a bad connection )
PostPosted: Mon Feb 19, 2007 6:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Makes sense, good you found it Smile
sneakthief
PostPosted: Tue Feb 20, 2007 5:07 am    Post subject: Reply with quote  Mark this post and the followings unread
andrewF - I was looking through Masa921's site and couldn't find the schematics for the microVCO. Are they available online anywhere?
thanks!
Sneak-Thief - raw electrofunk
211
PostPosted: Tue Feb 20, 2007 6:08 am    Post subject: Reply with quote  Mark this post and the followings unread
http://masa921.hp.infoseek.co.jp/synth2.htm
But there's no schematics..
It's Korg MS 10/20/50 design I guess.
2 2SK30 FET / 2SA733 2SC945 transistors.
Expo converter is 2SC1583 based, Volt/oct & Volt/hertz control and output easily tri and square signals.
Does anyone test this design ? Is it stable enough ?
andrewF
PostPosted: Tue Feb 20, 2007 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Masa921 used some different transistors for this design. I have no idea how you would go with substituting, the FETs are probably the fussiest.
There are some amazing pics on the link above provided by 211- why use circuit boards when you have a blob of goop?
sneakthief
PostPosted: Tue Feb 20, 2007 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks!!! i'd love to try this sometime.
PostPosted: Tue Feb 20, 2007 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
oha, these transistors seem very exotic to europeans, i think. i bet they are hard to find!
23isgood
PostPosted: Tue Feb 20, 2007 4:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow nice! So does this micro VCO perform as well as a typical VCO?
23isgood
PostPosted: Tue Feb 20, 2007 8:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
What does the upward pointing black arrow supposed to go to? The one labeled "BIAS"? Is this supposed to be connecting to -12v? Will some resistors be enough to take +-15v down to +-12v?
thanks
pete
andrewF
PostPosted: Wed Feb 21, 2007 12:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
I was impressed with the sound of this cct but i only heard it for a few minutes.
doubt it will be as stable as a typical VCO, no temperature compensation for a start. Maybe if you used the V/hz input it would be okay.
i suspect the reason the entire cct is built into a little compact blob is so all the transistors can warm up to the same temp and attain some stability, like the EFM chip heater VCO perhaps.
it is a very basic cct, don't expect too much from it. If you already have one or more wizzbang VCOs, this would be a good supplement.
it runs on +12V, +6V and Gnd.
Generally, it would be better to use 7812 and 7806 voltage regulators rather than resistors (with resistor dividers - as the current increases, the voltage changes).
That said, if you are breadboarding, try a resistor divider, it might prove interesting...or not Wink
23isgood
PostPosted: Wed Feb 21, 2007 12:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Well I have plenty VCO's but I really want to build a small compact synth that is portable and this VCO would be a nice addition. With a few pic modules it could happen.
thanks
pete
janvanvolt
PostPosted: Wed Feb 21, 2007 11:01 am    Post subject: Reply with quote  Mark this post and the followings unread
the 2SA and 2SC types are sold by reichelt
the 2SK is sold by banzai.
just ordered mine ...
just as of the design, do i get this right:
- LIN CV jack in
- HARDSYNC jack in
- Oct/V CV jack IN
- VCO jack out
- Pot for COARSE ? (below Oct/V)
- pot for LIN CV
anything i missed ?
PostPosted: Wed Feb 21, 2007 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
okay - not exotic.
etaoin
PostPosted: Wed Feb 21, 2007 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
You might not know this, as you are in Germany, but Reichelt have a minimum order of 150 euros outside of Germany. So they're actually very expensive just to get a couple of trannies.
janvanvolt
PostPosted: Wed Feb 21, 2007 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well. If somebody want's to do a groupbuy, i can handle this.
andrewF
PostPosted: Wed Feb 21, 2007 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
- LIN CV jack in
- HARDSYNC jack in
- Oct/V CV jack IN
- VCO jack out
- pot for LIN CV
anything i missed ?
Looks good
The BJT transistors are just AF complementary npn/pnp types, probably not much different to 547/9s or whatever you normally use in synth ccts.
In my experience FETs can be fussier.
the19thbear
PostPosted: Mon Apr 23, 2007 4:36 am    Post subject: micro vco
Subject description: micro vco
any schematics for the microvco? i checked out the website and it was in chinese Shocked i'm a newbie so i need some help--
andrewF
PostPosted: Mon Apr 23, 2007 8:03 am    Post subject: Re: micro vco
- Japanese!
there doesn't seem to be much synth diy in China ...yet.
the schematic for Masa's microVCO is on this thread - near the start
check out another thread on the microVCO -
http://electro-music.com/forum/topic-16600.html
Also these links take you to Takeda's version of the microVCO
http://www.aleph.co.jp/~takeda/radio/harvest/img/schem/DualTBVCO3a-schem.gif
http://www.aleph.co.jp/~takeda/radio/harvest/pdf/DualTB-pattern.pdf
