Tim Kleinert
G2 patch files: 236
Posted: Thu Jan 06, 2011 2:21 am Post subject:
Anti-aliased DIY Oscillators Subject description: implementing the DPW technique |
This patch generates a smooth sawtooth wave via the DPW (differentiated parabolic waveform) method.
Anti-aliased DIY oscillators, at last.
Unfortunately the expo tracking precision problem remains due to the inaccuracy of the LevelScaler module. But at least now there is no tracking resolution problem anymore, as this design uses true modulo counters without generating jitter.
t
UPDATE: expanded version offering variable width pulse wave added.
| Description: |
| DIY sawtooth oscillator with DPW anti-aliasing |
 Download (listen) |
| Filename: |
DPW-AA-SawOsc_TK.pch2 |
| Filesize: |
1.65 KB |
| Downloaded: |
2126 Time(s) |
| Description: |
| Expanded DIY oscillator with DPW anti-aliasing, offering saw and pulse wave |
 Download (listen) |
| Filename: |
DPW-AA-SawPulsTK.pch2 |
| Filesize: |
2.16 KB |
| Downloaded: |
2201 Time(s) |
dorremifasol
Joined: Sep 28, 2006 Posts: 823 Location: Barcelona, Spain
G2 patch files: 49
Posted: Mon Jan 10, 2011 2:37 am Post subject:
Tim, this is very impressive! Thank you for sharing such great patches.
I can't wait for a version using user definable waveforms  _________________ Cheers,
Albert |
WhitePony64
Joined: Oct 23, 2010 Posts: 5 Location: Auckland, New Zealand
Posted: Sat Mar 05, 2011 5:01 pm Post subject:
Hi all,
I'm just trying to get my head around all the timbre changing patch components I've been looking at lately.
Would I be correct in saying that these antialiasing oscillators are designed to reduce the disadvantages of using a a digital system with a fixed sample rate, as opposed to one with an infinite analogue spectrum?
Would I also be correct if I said that the purpose of these antialiasing oscillators is different from Rob's Tilt Filter and that to get the warmest/most analogue sound out of a patch I should use both together?
Sorry, I'm just trying to understand it all!
Thanks. |
Tim Kleinert
G2 patch files: 236
Posted: Sun Mar 06, 2011 9:58 am Post subject:
All stock G2 oscillator modules are already sufficiently anti-aliased. The aliasing problem occurs when rolling your own. This patch shows how to suppress aliasing on a primitive counter circuit DIY sawtooth oscillator using the DPW technique.
It's just an experimental patch that probably isn't of much use to anyone , but shows that DIY anti-aliasing of some sorts can be done. I like to dabble around with this kind of seemingly useless "low level" stuff, as sometimes you occasionally really do find a real practical use for it later on.
If you are looking for techniques to beef up the G2 sound, check out my "oscillator warmth" circuit. It's sort of a "tilt filter for oscillators".
http://www.electro-music.com/forum/topic-34508.html |
WhitePony64
Posted: Sun Mar 06, 2011 2:52 pm Post subject:
| Ohh, I see. Cool, thanks for the reply! |
