TH VCO-1 and XR-VCO?
Page 1 of 2 [40 Posts]
zthee
PostPosted: Tue Feb 26, 2008 2:17 pm    Post subject: TH VCO-1 and XR-VCO? Reply with quote  Mark this post and the followings unread
I've started to plan the building of my modular. Got some EFM-modules done already, just ordered som CGS PCBs. But when it comes down to VCOs I'm kinda lost.
For a long time I thought about the CGS VCO. It looks like it's a great VCO - though I haven't really read any reviews of it. So I don't know..
Anyway - my current thoughts lean towards using 2 VCO-1 and 2 XR-VCO.
Let me explain; They look kinda easy to build? They don't have like 20 ins and outs (This might be a downside aswell, but as for now I think it's a plus). They're simple and elegant VCOs. They cover the most basic needs - VCO-1 has PWM and XR has skew and sync.. and with the bugbrand mod you can have the XR as an LFO.
They are to be used mostley for bleeps, squeeks and sometimes melodies.
I guess my questions are:
Are they hard to build? (I did put together a x0xb0x in just about 3 days..)
Do they stay somewhat in tune over atleast some time? (not tuning every day..?) - I don't know why I really care about this Very Happy
Or am I just being unimaginative here - and should I go for the CGS VCO instead?
(I mean it's a modular, I've got all the possibilities to expand it later) - but as a first choice..
I think this just turned into one of these dreadfull "Is this right for me"-threads. That wasn't my intention. I just wanted to know -
Should I reconsider or is it a cool idea?
Smile
Coriolis
PostPosted: Tue Feb 26, 2008 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I built the VCO-1 as my first module and it's worked fine ever since. Tuning stinks, but that's because I put an NTC thermistor in it instead of a PTC (so actually worsening the temp drift of the expo pair Embarassed ).
The original layout only has space for an expo pair made of either discrete transistors or metal can duals, so DIP duals can't be used without a bit of kludging - could be a downside. I couldn't quite get a decent sinewave out of it, but it's my only vco sofar (building an XRvco right now as my second) and I don't have a scope, so what do I know?
If I got my shit together and corrected a few things, it would be a cool vco.
Although...the XR has a sync in, which the VCO-1 doesn't...
C
zthee
PostPosted: Tue Feb 26, 2008 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, better becarefull with the thermistors then Very Happy
About the matching of the transistors - It's just to match them by hand by the HFE numbers? If i go discrete (which I intend to do, I think).
I think the VCO-1 and the XR compliments each other in a nice way.
Pehr
PostPosted: Tue Feb 26, 2008 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
The XR-VCO looks really nice with its skew-function. Cool I'm at least going to build one.
Regarding the ins and outs, I often find myself using more than one CV-inputs. For example, you might want a VCO to be controlled by a keyboard, sequencer and a LFO at the same time, thus many CV ins could be usefull. However, that could be achieved with other DC mixer modules...
Also I very often use the saw-output of my oscillators, which the VCO-1 don't have.
I have built 4 MFOS VCOs and I pretty pleased. However, I have to trim them again now after the winter since the sine waves are 'popping' Rolling Eyes
Oh, and also, a sync input is very useful for sweeping effects Cool
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
zthee
PostPosted: Tue Feb 26, 2008 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pehr, The MFOS VCO looks good! I've been looking at some of the MFOS parts for a long time (I mean, everyone do need a WSG right?). It could be a good idea to have it as a project in the future..
And you're right about the ins and outs. I tend to use all my 4 inputs into the EFM filter module. But Since I'm trying to get as many modules as possible into the smalles space possible I have to make some sacrifices.. (I'm thinking of building a small DC-mixer break-out-box, it might be a good idea). But the possibilty to connect both sequencer, lfo and envelope to the input of oscillator is a must! Smile
RF
Audio files: 28
PostPosted: Tue Feb 26, 2008 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd second Pehr on the MFOS VCO's.
They are very well documented, easy to set up and find parts.
I've got a bunch of those in my modular.
bruce
crashlander42
PostPosted: Tue Feb 26, 2008 7:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm a big XR VCO fan. I've built 3 of them now. They seem stable enough, are fairly cheap to build, and are simple to build. I've also built 2 VCO-1's and haven't had any problem with them. I was very careful about matching the transistors.
When they plug me in the lights go down in Hong Kong.
My DIY stuff Flickr
numbernone
PostPosted: Tue Feb 26, 2008 7:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have a pair of MFOS and three of the XR. The MFOS oscillators have most of the options you are gonna need, lots of waveshapes, PWM. The XR is really pleasing to my ear, and the VC waveshape/rampoid is great fun, which Im only now 6 months later starting to really exploit. My philosophy is build a ton of everything. I am finishing up 4 8038 VCOs currently, the are pretty vanilla but I fit them into about 3 square inches each, and I like to build small. Yusynth will probably be next, then hopefully somebody will roll out a DIY thru zero model.
neandrewthal
PostPosted: Tue Feb 26, 2008 9:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm enjoying my MFOS VCOs, though I kinda wish I had used the Temp-co resistors as they are kinda drifty. I didn't think this would be a problem for me, but after using my modular (my first true modular experience) I realize the benfeits of stable oscs. Mainly for making finely tuned cross mod sounds that are consonant(not that a little dissonance is a bad thing though)
The CGS VCO can be as fancy or simple as you want it, as evidenced by the 4U width! Motm version shown in the Modular Synth Panels Yahoo group (I wish I could link to the file, but you have to be a member) and Richard Brewster minimalistic layout here: http://www.pugix.com/cgs-vco.htm
Thomas Henry
PostPosted: Tue Feb 26, 2008 10:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just delivered a keynote presentation for our STEM Summit (Science, Technology, Engineering and Mathematics) today to 350 highschool students considering a career in the sciences. My topic was mathematics and music, with an emphasis on Fourier series and synthesis.
Anyway, I used the VCO-1 for all of my demonstrations. It was rock solid for all of the demos, and sounded superb through the one dozen Mackie speakers in the auditorium at a very loud volume.
That's the VCO I turn to when tuning accuracy matters more than anything.
And, oh, I made the local television news---the first time I've been on the tube. I feel just like Brittney now, but I'm not going to shave my head (or anything else, for that matter).
Thomas Henry
zthee
PostPosted: Wed Feb 27, 2008 12:03 am    Post subject: Reply with quote  Mark this post and the followings unread
I was hoping you'd make it easier for me, but instead I feel like I just want to scream: Give me more of everything!! I need atleast 20 XR-VCO! 40 MFOS VCO and 10 CGS VCO with 20 ins and outs! Smile
And instead of a small modular I've got this huge modular wall in my head. I really have to make it go away.
But I think I'll start out with the XR and VCO-1 and see. If they don't appeal to me after playing with them for a while, I guess I'll go for the MFOS instead..
zthee
PostPosted: Wed Feb 27, 2008 6:23 am    Post subject: Reply with quote  Mark this post and the followings unread
What DIP transistor is recommended as replacement for 2n3906? LM394?
I've come to the conclusion that it might be easier to get one super matched DIP (and go for the kludging and a few cm of extra wire..) instead of buying 100 2n3906 and trying to match them by hand..?
Pehr
PostPosted: Wed Feb 27, 2008 6:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I use SSM2210. Abt 50 kr on electrokit.se
http://electrokit.se/item_show.php?code_no=40352210
Cool
EDIT: Oh, you mean PNP. doh
See SSM2220 http://electrokit.se/item_show.php?code_no=40352220
YouTube channel
flickr photostream
zthee
PostPosted: Wed Feb 27, 2008 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I think'll use that instead Smile
numbernone
PostPosted: Wed Feb 27, 2008 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I have also used the SSM2210 with tempco on the MFOS and XR boards. The 8038 was a nice cheap treat with the 2sa798 at $.45 each!
23isgood
PostPosted: Wed Feb 27, 2008 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I built three XR2206 VCO's and they are rock solid. I used tempco's from MFOS. These have been the easiest VCO's to build, and I use them exclusively. They sound clean and great, though you can get grungy sounds if you like too. The only thing is, I wish they had PWM. Other than that I highly recommend them. Oh and they where dirt cheap. I think I spent around $40.00 on each of them.
pete
Check out my music
Scott Stites
Audio files: 96
PostPosted: Wed Feb 27, 2008 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
VCO-1 is more of a classic, straightforward VCO, while the XR gives you some really spiff stuff (not least of which is that uniquely implemented sync portion) - at least one of each would do it. Very Happy
Cheerio,
Scott
My Site
zthee
PostPosted: Wed Feb 27, 2008 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys! You're help is really appreciated!
Damn, I want my PCBs now! Very Happy
Good thing I got other projects to keep me occupied.. Wink
numbernone
PostPosted: Wed Feb 27, 2008 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
What differs in the functioning between VCOs and LFOs in terms of sync? The sync on the XR is great, however when I kick it down to LFO territory, and try to reset the cycle, no dice.
What gives??
I am working on the Yusynth VCLFO to remedy this situation. Very Happy
Scott Stites
Audio files: 96
PostPosted: Wed Feb 27, 2008 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
The XR VCO sync is a bit different than a standard VCO sync - it actually takes advantage of the FSK function of the XR2206 - it's not resetting the VCO per se, but rather shifting it way off frequency each time a pulse arrives (as I understand it) - that's the weirly unique thing about it.
I use Rene Schmtiz's VCO3 a lot - that is a VCO with such a wide frequency range, it's not even funny. It easily goes to cycle/coffee break range, but the sync still works down there - makes a great syncable LFO in that mode.
Cheerios,
Scott
My Site
frijitz
Audio files: 54
PostPosted: Wed Feb 27, 2008 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Interesting. That sounds somewhat similar to the "kick" sync in my super Tri VCO. In that one, short sync pulses nudge the system into sync gradually. I thought this was a clever invention at the time, but it turns out that Curtis used it years before.
Yep. Some designs you don't even have to try out, you can just tell by looking that everything is done right. It's not that hard -- low leakage and offset in the integrator and a fast switch are the main things. It's amazing to me that there are still designs out there that use jelly-bean opamps or other inadequate devices. I probably should shut up and made a board, right?
Ian
fluxmonkey
PostPosted: Wed Feb 27, 2008 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
frijitz wrote:
... I probably should shut up and made a board, right?
Ian
Ian, if yr gonna do a VCO board, how about a version fo the ultrasonic VCO/digital waveform generator from electronotes? doesn't seem to be anything like it out there...
Smile
b
Thomas Henry
PostPosted: Wed Feb 27, 2008 7:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
With regard to the sync, yes, it's using the FSK capability of the XR chip. But just as important are these two properties:
1. The period of the reset pulse is much more narrow than the period of the dummy second (super high frequency) FSK signal , and
2. The XR chip always starts the alternate FSK signal from wherever the other leaves off. (It's phase continuous).
Put these together, and in effect the output signal is always being reset to some value close to 0. It may not be exactly 0, but it will be consistent from cycle to cycle, and is indistinguishable to the ears.
I've never seen this used before, but that's because I've never seen a chip like the XR which has switchable dual current sources.
Thomas Henry
zthee
PostPosted: Fri Mar 28, 2008 12:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Finnished my first XRVCO yesterday. And it works (and sounds) like a charm! Very Happy
Also completed a VCO-1. But it didn't produce any sound. I need to look at it today and see what could've gone wrong with it.. (I wasn't surprised though. I built it on the copperside of a mirrored pcb).
numbernone
PostPosted: Fri Mar 28, 2008 7:19 am    Post subject: Reply with quote  Mark this post and the followings unread
OOOO neat, can you post a forward shot of that panel???
Looks kinda like a Harvestman style.
Isnt the XR awesome?? Do yourself a favor and dont sleep on the VC Skew like I did for months, it is so so sweet.
