Can MFOS VCO Use 3300 2K Tempcos from SynthCube?
Page 1 of 1 [2 Posts]
jbeuckm
Audio files: 9
PostPosted: Thu Oct 01, 2015 9:50 am    Post subject: Can MFOS VCO Use 3300 2K Tempcos from SynthCube? Reply with quote  Mark this post and the followings unread
Ray says 1/4W but these are 1/6W. Is that sufficient?
http://synthcube.com/cart/SDIY-Parts?product_id=205
m.o
PostPosted: Thu Oct 01, 2015 2:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would say yes.
My back-of-the-napkin calculation gives something like 1mW on that resistor with max CV (5x(15V over 100k) = 0.75mA into the op-amp, the amp sends the same current through the tempco -> 0.75mA over 2k = 1.5V, P = 1.5V x 0.75mA = 1.125 mW).
I might be off on my calculations, but there should most likely not be a problem.
