 Forum index » Instruments and Equipment » MIDI Controllers and Interfaces
How to use "Run" on a midi controller
Page 1 of 1 [5 Posts]
stickysynth
PostPosted: Mon Dec 05, 2005 9:20 am    Post subject:  How to use "Run" on a midi controller Reply with quote  Mark this post and the followings unread
I would like to know how to use the "run" button on a midi controller ....or any midi surface .... Embarassed
Audio files: 233
PostPosted: Mon Dec 05, 2005 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome Dave.
I'm not sure I know what "run" button on a MIDI controller is. Maybe it is used as a clock start signal.
Moving this to the MIDI Controllers forum as it is not a G2 FAQ exactly...
stickysynth
PostPosted: Mon Dec 05, 2005 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
thank's for the tips
PostPosted: Mon Dec 05, 2005 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I would like to know what midi controlers come with a "run" function? That sounds quite cool!
You could hit a button labeled "list"
and the controler would output something like;
10 BEEP
20 GOTO 10
On it's LCD schreen after which you'd hit this "run" button. It'd be so much fun!
egw
G2 patch files: 8
PostPosted: Mon Dec 05, 2005 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I guess that "run" is the same thing as "start".
Which mostly tells a sequencer to start playing.
Works on some arpeggiators too.
Some devices will only send clocks after receiving this.
