why I won't replace my G1 with a G2
Page 1 of 1 [14 Posts]
kmmcdonald
PostPosted: Sat Feb 10, 2007 9:11 am    Post subject: why I won't replace my G1 with a G2 Reply with quote  Mark this post and the followings unread
My G1 (rack) has been my main machine for at least seven years, in my home studio. While it does not sound as good as some of my other equipment, it has a sizzle that sits well in a mix. Anyhow, I occasionally toy with the idea of upgrading, but it eventually comes down to this:
1) G2 has no filter bank, which is generally the only way I've found to add fullness and smootheness to an otherwise "sharp" sound
2) From what I have read, the G2 doesn't sound any different or better than a G1. Unfortunately, I have no opportunity to listen to a G2 myself. While the G1 definitely sounds "clean," an improvement would have been attractive.
And the main reason:
3) No rack module with knobs. I don't need an additional keyboard in my setup. For me, the NM1 module is the ideal configuration
Things that could change my mind:
1) MN1 editor no longer works as PC OS's evolve
2) Audibly superior sound
3) Digital output
4) rack version with knobs (like G1 module)
Too bad for me.
Keith
P/S. The syncable LFO's of the G2 area ttraceive to me, but not enough to push me over the edge.
Keith M in AZ
Audio files: 297
PostPosted: Sat Feb 10, 2007 10:15 am    Post subject: Re: why I won't replace my G1 with a G2 Reply with quote  Mark this post and the followings unread
It does sound different, some like the Classic better others the G2.
For me ... IMHO ... I'd say the G2 sounds cleaner in general, the Classic has more character of it's own. Meaning that the G2 can be used for more sound types, but it's harder to make something characteristic, but you've got more DSP to spend on it as the DSP's run faster.
Audio files: 224
PostPosted: Sat Feb 10, 2007 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
You have good reasons. The G2 has a better control surface, interslot communication, better MIDI, variations, and the control sequencer. Still, if the G1 is doing it for you, why change? Is someone asking you to replace your G1 with a G2, or are you seeking reassurance?
kmmcdonald
PostPosted: Sat Feb 10, 2007 4:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am looking for alternate points of view in case I am wrong on some points, or there is something that I have not considered.
So, you could say that I am seeking the opposite of reassurance.
Keith
Keith M in AZ
PostPosted: Sat Feb 10, 2007 5:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
The G2 is a wonderful machine which absolutely is worth its price. My own opinion of it is that it is not really an an upgrade of the NM-1, but rather almost the same thing but slightly different. It has several improvements of the design, but it doesn´t make the NM-1 obsolete in any way. Some of the perceived improvements are more like different design choices rather than true improvements. Bottom line is that the G2 is a G2 and not a better NM-1. You might love to own both. Wink
Much would of course be different if Clavia had implemented patch compatibility, included the same modules as in the NM-1 and added some small extras. This does not mean that I think the G2 really lacks any major features. The basic concept of the G2 is the same as the NM-1. You get an extremely powerful modular synth and you save a lot of money because the interface to the modular synthesis is software based and not included in hardware by Clavia. The control surface is more modern than what you have on the NM-1.
Flickr
PostPosted: Sat Feb 10, 2007 6:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
The title of this topic says it all.
Frankly, I don´t think the bright minds at Clavia really intended to make a replacement, but rather they felt they could implement the inital design ideas behind what became the NM-1 in a way that would result in a slightly more modern product.
Flickr
varice
Audio files: 29
G2 patch files: 54
PostPosted: Sat Feb 10, 2007 11:22 pm    Post subject: Re: why I won't replace my G1 with a G2 Reply with quote  Mark this post and the followings unread
The G2 has EQ and filter modules which can be used to sculpt the sound. Anyway, it would still be best if Clavia had included the fixed filter bank in the G2.
By my own listening tests, the G2 has less aliasing than the G1.
This is the reason that I almost did not get a G2! A G2(X) Rack would have been my first choice and would have been a better fit for my home studio. The blank Engine and the little 3 octave G2 Keyboard were non-starters as far as I was concerned. If the G2X had not been released, I may still be without a new G2. If Clavia released a G2(X) Rack, it would be hard for me to resist getting one to expand my system.
varice
varice
Audio files: 29
G2 patch files: 54
PostPosted: Sun Feb 11, 2007 12:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm.... I guess it depends on how much that you might use the new G2 features. I use the MIDI modules, the interslot I/O signal buses, and the patch variations very much. I consider these to be significant new features, along with the much improved control panel.
I have to agree with the disappointment in the fact that Clavia did not make the G2 compatible with G1 patches. They made an effort to make the G2 able to be programmed to reproduce Yamaha DX7 sounds, but did not make it able to load tens of thousands of existing G1 patches! What were they thinking? I also agree that this means that the G2 did not make the G1 obsolete. I have G1 patches that I cannot reproduce on my G2X. I'm lucky that I did not have to make a choice between a G1 or a G2, I could have both. Still, I have now made my G2X the main synth, my G1 Rack does not get very much attention.
varice
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Feb 11, 2007 4:36 am    Post subject: Reply with quote  Mark this post and the followings unread
I will never part of my NM Classic... It means a lot to me, because it made me possible to meet a large group of friends, mostly international.
The NM Classic wasn't intended to be released at all. It was developed as a possibility using the sound engine of the NordLead, to be used as a developing tool by Clavia itself. One of the designers had the idea already a long time. Swedish musicians asked Clavia to release it. It was to be seen as a Swiss Army knife, a synth which could do a lot of things more then other synths. Later on, the NordLead3 was developed using the NM Classic.
The problem was the CPU was to 'small' to develop the system further: it appeared to be a bottle neck in the Classic. A new platform, developed while discussing it with some heavy users in the world (pre alpha testers Wink was made: the G2.
Like the Classic before the G2 wasn't their most important product, so there were some decisions made, which can be called 'questionable', like releasing it with a three octave keyboard and releasing the G2X only one year later...
I still have on the computer the text of a lecture once given by Clavia about the history of the Nord Modular, but I never had permission to publish it. It was given at the start of the development of the G2. Next Frankfurt, while looking at their new baby, I will ask them permission to publish it here.
Wout
PostPosted: Sun Feb 11, 2007 7:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Okdokey, this is starting to make some sense now. Laughing
Flickr
davep
Audio files: 10
G2 patch files: 73
PostPosted: Sun Feb 11, 2007 2:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tend to agree with you. If I had sold the NM1 and replaced it with the G2 it would have been a bad move, mostly because of losing a massive amount of NM1 patches. However, I'm very glad I have a G2 in addition to the NM1. If you can justify the expense, it's a great synth for someone who already has the NM1 because you already know most of the features and UI but you get quite a few new things, as mentioned in other posts. Having both is great.
And yeah, it's too bad about the lack of rack version with knobs. I STILL don't understand that. They should have released a rack box with knobs instead of the three octave version. The five octave verson and the Engine make sense, but an incredibly complex synth with a stubby three octave keyboard? In the end, I worked it into my rig OK but it still seems like an odd choice to me.
Dave Peck
Audio files: 224
PostPosted: Mon Feb 12, 2007 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, the day my G2 arrived I sent of my NM1 to a friend so he could experience the Nord Modular world. I have zero regrets. I would like to get a NM micro though. Those are handy things to have in your kit.
PostPosted: Mon Feb 12, 2007 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
sunny love
Flickr
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon Feb 12, 2007 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I do not miss my Papa Nord (NM Classic Key) at all.
With qfinger's patch converter I brought in what I had in papa nord -- there is even less reasons to miss it.
The G2 has the features (variations, Midi Out, fx) and interface (grid x0x editing and easy/quick patch editing without a computer) that is closer to my ideal than the old modular.
The filterbank would be nice so would the spectral osc, but I hardly used them in the old modular, thus ...
However, I do regret what I bought with the money I got for it. But the problem is that the Nord (papa and g2) have spoiled me with the ease of use and intelligent design, which makes using any other devices which are not at par with the nords quite difficult and unappealing.
To each their own.
/Dasz
