Thomas Henry XR-2206 VCO Page is Up
Page 2 of 3 [75 Posts]
fluxmonkey
New postPosted: Thu Jul 27, 2006 1:08 pm    Post subject: Re: Thomas Henry XR-2206 VCO Page is Up
Subject description: Spiffy Low Parts Count VCO with VC Skew
Scott Stites wrote:
Finished the basic page - only have one sound sample, so more will have to be added.
http://mypeoplepc.com/members/scottnoanh/birthofasynth/id20.html
Schematics, board layout, parts list, waveform pics included.
scott,
just saw your notice on the webpage about the error in the schematic and pcb layout. thanks for the workarounds... do the schematics/pcb PDFs now reflect the fix? probably would be good to add an revision note on the pdfs themselves, just to keep everything clear.
thanx for all
bbob
Scott Stites
Audio files: 96
New postPosted: Thu Jul 27, 2006 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi BBob,
Nope - the PCB doesn't reflect the change. I don't have the original copy of the PCB layout. All of that came from Thomas. I'll pass that along, in case he intended to correct it, but never got around to it. I'm afraid the only (crude) means I have of correcting it may distort the scale.
Scott
bugbrand
New postPosted: Fri Sep 22, 2006 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Hiya
I've just done a PDF document with my PCB for the XR2206 VCO
(also its linked on my electronics page)
Its pretty compact so maybe its a bit messy but it is verified and also has the diode update that's missing off the original PCB.
Hope its all working ok - comments etc very much appreciated - - build one and double check -- they're great!
http://www.bugbrand.co.uk
Scott Stites
Audio files: 96
New postPosted: Fri Sep 22, 2006 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Fan-freakin-tastic!!!!
I'll link this from my TH XRVCO page as well.
Thanks Tom!!
Scott
bugbrand
New postPosted: Fri Sep 22, 2006 7:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Super happy to help!
synth_ollie
New postPosted: Mon Jan 08, 2007 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
I can not find lm394 or ssm2210, but I guess mat02 will work as well ?
cheers
OLLIE
vtl5c3
New postPosted: Mon Jan 08, 2007 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
MAT02 should be fine. I've used them in other VCOs, such as the CGS 48 VCO and no problems so far.
bugbrand
New postPosted: Mon Jan 08, 2007 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
cheers
OLLIE
You should still be able to get free samples in Sweden from www.analog.com
(register, then order samples)
synth_ollie
New postPosted: Mon Jan 08, 2007 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks, but a friend had some mat02´s that he gave me Smile
Im gonna use your layout bugbrand, have you built it, is it ok ?
(I may try to get some samples from analog later.....)
also, I´d like an octave swicth on my 2206 vco, found this
http://me.ineptum.home.comcast.net/asm-1/vcoexp.gif
mikeb
New postPosted: Tue Jan 09, 2007 9:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
A few years ago, to do octave switching (I had 3 octaves actually) with my simple xr 2206ciruit I just switched out the timing capacitor. This is C7 on Thomas Henry's circuit and is .047uF. This is what I did:
I matched a bunch of capacitors (I was using a different value for my circuit) by building my basic XR2206 circuit and putting in different capacitors with the output hooked up to a tuner. Then I'd select two that "matched" when they outputted nearly the same frequency. Then to do the switching, I used a rotary switch to switch the capacitors to parallel, single and series. 3 different octave settings.. perfectly in tune.
I can draw up a little wiring diagram for how the parallel/single/series switching works if you want..
synth_ollie
New postPosted: Wed Jan 10, 2007 9:32 am    Post subject: Reply with quote  Mark this post and the followings unread
yes please ! Smile
....and where can I find lm442´s ?
mikeb
New postPosted: Sun Jan 14, 2007 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
synth_ollie wrote:
yes please ! Smile
Okay, this took me a few days to draw because of all the amazing photoshop that it required... sorry about the delay:
As for the LM442 mentioned on that XR-2206 VCO page, it's actually an LF442. It's correct on the parts list pdf, but not on the website. I got them from digikey, but I just realized futurlec also has them.
Scott Stites
Audio files: 96
New postPosted: Sun Jan 14, 2007 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for noticing that - it's fixed.
Scott
etaoin
New postPosted: Sun Feb 18, 2007 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd like to report a succesful build of the Bugbrand PCB. It is working fine, although the XR is running slightly warm. Should it do that?
Scott Stites
Audio files: 96
New postPosted: Sun Feb 18, 2007 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't recall offhand, maybe Tom does.
How warm, warm as in "I feel a bit feverish today" or warm as in "Damn, that thing burned my finger"?
Scott
mikeb
New postPosted: Sun Feb 18, 2007 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
My XR-2206 gets warm as well, but not too warm to touch. I can leave my finger on there forever if I want, without discomfort.
bugbrand
New postPosted: Sun Feb 18, 2007 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
...I don't know offhand -- never noticed it but hadn't much reason too, I guess.. I'm away from home still for the next week & I'll try to check once I'm back.
Glad its worked out ok for you!
Fernando
New postPosted: Tue Feb 20, 2007 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
zipzap wrote:
Have fun!
BTW, i understand that a simple circuit is what you want. If you can live with another pot and jack than consider using pin 1 for am. I had so much fun with that. Just don´t know if it can be implemented alogside the vc skew circuit. Don´t really yet understand how that´s working...
zipzap wrote:
Well, giving it a closer look i see that i missunderstood something there. While experimenting with the chip i was getting a ramp-wave by connecting the pulse out to the fsk in, just like in the datasheet. than the resistor value at pin 8 had the effect i just described.
Now in this case the ramp must be made somehow different. Can´t use my right hand right now. As soon as i can i´ll check this out. Good way to learn by building a design, than experimenting with values, see what happenes.
About the AM, I was writing about it in the other thread, I like that it is bidirectional with negative cv inverting the wave, like a rigmod. On the scope it looked way different than what´s going on with that vc-skew. But very often things like that sound very much the same, although the effect is created differently. So there is no benefit in adding too much, just because it´s possible. Have to force myself not to want a pot for everything sometimes.
But --- maybe fast AM and slowly modded skew will sound great, unheard? I don´t know...
I'd like to know how you did AM to pin 1.
Could be implemented with a switch? (to have skew control or AM)
I'd love to have AM on a VCO internally saving an vca. Turning signal negative with negative cv can be interesting too.
Maybe you did some experiments from that July '06 post?
mikeb
New postPosted: Tue Feb 20, 2007 3:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fernando>
For AM on an XR-2206 @ pin 1, the amplitude is 0 at VCC/2. So if you're using TH's XR-2206 circuit, it's at 7.5V.
so 7.5V is 0 amplitude.
11.5V is 1 (full) amplitude.
3.5V is -1 (full, but flipped) amplitude.
So I'd connect a Pot up, one end to +15, one end to -15 and the wiper going to the AM pin. This will be the "amplitude center" adjustment. That is, adjust it to output 7.5V if you wish it to be centered at 0 amplitude.
Then connect up a jack going to the AM pin as well, and there's your voltage control input.
Worth a try! Try it in conjunction with the skew, it should just make weirderness i THINK Smile Otherwise, add a switch as you mentioned to disable the skew when you want...
Fernando
New postPosted: Tue Feb 20, 2007 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
great, thank you!!
but, to use it while the skew circuit is present, one should isolate that AM input somehow? A voltage mixer or something?
Or it's OK in the raw way you described?
...raw because it works well like that? or driven by a wild experimental spirit?
mikeb
New postPosted: Tue Feb 20, 2007 7:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fernando wrote:
great, thank you!!
This isn't anything I've actually TRIED yet Smile
Fernando
New postPosted: Wed Feb 21, 2007 2:28 am    Post subject: Reply with quote  Mark this post and the followings unread
hehe, okay!
mikeb wrote:
Fernando wrote:
great, thank you!!
This isn't anything I've actually TRIED yet :)
mikeb
New postPosted: Wed Feb 21, 2007 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fernando> I'll give it a try tonight or something and report back the results. My only issue that I see happening is that reliably getting VCC/2 exactly (to produce 0 amplitude) is going to be hard, so I can always picture a bit of audio leaking out. Which isn't a big deal if you want to just send an LFO to the fake "VCA" portion. But if you want to make a proper controller for the audio, like a foot pedal or something, then getting that VCC/2 point would be tricky I think.
Fernando
New postPosted: Wed Feb 21, 2007 4:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
maybe you could open a switch and let the voltage you want to pass thru.
That voltage being constant, you only let the door open or close.
Two complementary doors for two voltages (2 and 0 V)
para
New postPosted: Thu Mar 29, 2007 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
i just finished up 3 of bugbrands XR boards, switchable to lfo so i'm wondering if and how i can add a speed indicating led?
any guesses
steven
