 Forum index » Instruments and Equipment » MAX/MSP - Pd
Wrong handling, need a restoration with a stable version...
Page 1 of 1 [4 Posts]
badiou
PostPosted: Mon May 07, 2007 8:39 am    Post subject: Wrong handling, need a restoration with a stable version... Reply with quote  Mark this post and the followings unread
Hello everybody,
as you notice certainly, I initiated two posts talking of a personal project : a video player dependaing on motion.
So, since I progressed well. But I made a bad handling, to the left of my patch, I've got a big (really big) toggle. This one is intended to activate the webcam. My error was to put a loadbang on this toggle.
Now I can't no more correct that, every time my software crashes...
Is there somebody who can (try) correct for me this patch (just remove the loadbang above the big toggle)....
Many thanks. You'll have all my grateful Smile
jitZissor.pat
 Filename:  jitZissor.pat
 Filesize:  14.68 KB
 Downloaded:  355 Time(s)
EdisonRex
Audio files: 172
PostPosted: Mon May 07, 2007 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Here, that should do it.
jitzissor_676.pat
 Filename:  jitzissor_676.pat
 Filesize:  11.85 KB
 Downloaded:  365 Time(s)
Garret: It's so retro.
badiou
PostPosted: Mon May 07, 2007 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
hello !!!
Thank you ! I apologise, I made a mistake, it doesn't seems to be the good patcher... Hope this one is good Wink
jitZissor.pat
 Filesize:  14.68 KB
 Downloaded:  366 Time(s)
EdisonRex
Audio files: 172
PostPosted: Mon May 07, 2007 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok, well, here again then. If you need to do this much more, PM me, no need to drag the rest of the forum through your tribulations.
jitzissor_206.pat
 Filename:  jitzissor_206.pat
 Filesize:  14.58 KB
 Downloaded:  361 Time(s)
