A6 and cubase
Page 1 of 1 [4 Posts]
amnesia
PostPosted: Thu Sep 27, 2007 3:19 am    Post subject: A6 and cubase Reply with quote  Mark this post and the followings unread
Hi
I am using Cubase for the first time with the A6. i can send and receive midi data, but when i set up a 2 bar loop and hit record all the notes i have played during the 2 bars are all in the exact same place in the bars is on top of each other....any idea why this is happening and how to change it?
I can move the notes about and A6 plays them, but have never come across this stacking in one spot issue before????
edobedo
PostPosted: Thu Sep 27, 2007 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you have some input filter or input quantization activated?
pophertz
PostPosted: Thu Sep 27, 2007 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi amnesia
If I understood you well this could be your problem: Quantize Type in your project is set to 1/1 (see picture Cubase MIDI 01). Simple solution is to click on little arrow and you'll get various quantize options (see picture Cubase MIDI 02). Choose option which suits you best.
Cubase MIDI 01
 Filesize:  236.46 KB
 Viewed:  491 Time(s)
Cubase MIDI 02
 Filesize:  237.21 KB
 Viewed:  464 Time(s)
amnesia
PostPosted: Fri Sep 28, 2007 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi
no quantize is set to 1/16
how would i know if i have an input filter set ?
