EqMid as a sound generator....
Page 1 of 1 [5 Posts]
delay19ms
PostPosted: Sat Sep 29, 2007 8:51 pm    Post subject:  EqMid as a sound generator....
Subject description: Had a strange sound in a patch
I had a strange sound in a patch and discovered that it was coming out from the EqMid module... even after turning off the oscs and everything i still had a sound... here is a simple patch doing that sometime on my g1,
you can trigger a note and turn off the osc and the red link (on off knob 1 and 2) and modify the sound using the eq knobs (7 8 9)...
maybe it is normal but i did not know...
eqmid-osc.pch
the patch
 Filename:  eqmid-osc.pch
 Filesize:  974 Bytes
 Downloaded:  210 Time(s)
eqmid-osc-wait-a-bit2.pch
another one
 Filename:  eqmid-osc-wait-a-bit2.pch
 Filesize:  1.32 KB
 Downloaded:  205 Time(s)
PostPosted: Sun Sep 30, 2007 8:03 am    Post subject: Re: EqMid as a sound generator....
Looks more like a bug, there are some more like this, pretty obscure. I didn't know this one either.
delay19ms
PostPosted: Sun Sep 30, 2007 8:23 am    Post subject: Re: EqMid as a sound generator....
Is there a list somewhere of all those little bugs? maybe in the forum somewhere with various exemples?
PostPosted: Sun Sep 30, 2007 8:36 am    Post subject: Re: EqMid as a sound generator....
If there is anything at all it could be in http://nm-archives.electro-music.com/010_NordModular/014_Interesting_Threads/ but I'm not too sure.
X-Electric
PostPosted: Mon Oct 08, 2007 12:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's pretty weird stuff. It works only below 300 Hz or so - I found the loudest signal at 20 Hz setting - it generates some sort of triangular wave - noisy stuff when changing frequencies.
