today> Twyndyllyngs reschedule: Sunday, Dec 6 Chez Mosc
Disabeling slots over MIDI?
Page 1 of 1 [6 Posts]
Kassen
PostPosted: Sat Sep 29, 2007 3:28 pm    Post subject: Disabeling slots over MIDI? Reply with quote  Mark this post and the followings unread
Is anyone aware of a way to send a MIDI message to the NM that tells it not to use a certain slot? Loading patches over MIDI is no problem but unloading doesn't seem to be documented? Is the only workaround to store a empty patch and load that?
Kassen
PostPosted: Sat Sep 29, 2007 3:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just CC7 I guess Very Happy
PostPosted: Sat Sep 29, 2007 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or hack the Nomad code and do it over the PC port ...
Kassen
PostPosted: Sat Sep 29, 2007 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm, that whole editor-synth hand-shake takes too much time for what I want. I think I'll load a blank patch then. Thanks.
Kassen
cappy2112
PostPosted: Tue Oct 02, 2007 8:15 pm    Post subject: Re: Disabeling slots over MIDI? Reply with quote  Mark this post and the followings unread
Is your goal just to silence the audio in a certain slot, or is there anther factor?
Kassen
PostPosted: Tue Oct 09, 2007 2:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, it's about automating the NM in my live-set. The NM is doing one lead and one bass line anyway but I'm considering that the two spare patches could keep themselves busy with stuff like FX. The main thing I want is turning off the leds for slot 3&4 when not in use to have a visual indication those aren't being used. That's basically the only thing I care about, it's not even about CPU cycles as I'm doing chords -where used- within one cpu because I'm morphing from note to note all the time and the build in polyphony management can't do that.
Silencing the audio isn't the hard bit :¬).
Kassen
