Save Patches into Slots
Page 1 of 1 [9 Posts]
Hello
PostPosted: Tue Nov 06, 2007 8:56 am    Post subject: Save Patches into Slots
Subject description: ughh
Hello. Wondering if there is any way to store patches into individual slots and have them STAY there. When i turn off Nord Modular my patches saved in individual slots don't stay there. I've turned off memory protect. In the manual it states that the slots are a temporary place to store patches. ugh.. is this true?
Best Wishes
doug Theriault
Audio files: 279
PostPosted: Tue Nov 06, 2007 9:41 am    Post subject: Re: Save Patches into Slots
You can save the current set of programs in the slots by doing a save of the synths settings:
p59 of manual
SAVE SYNTH SETTINGS
Pressing SHIFT+STORE will store any settings that you have made in the Synth Settings menus of Nord Modular or in the Editor. This function saves the SLOT selection including the patch locations that were loaded to the SLOTS, MIDI channels for the SLOTS and PANEL SPLIT activation. The settings saved with SAVE SYNTH SETTINGS will automatically be recalled when you turn on the Nord Modular. The Synth Settings menus will be described further in “Synth settings in the system menu” on page 52 and page 69.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Nov 06, 2007 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome Doug Theriault
'Save Synth Settings' works for only one set up for all four Slots. Normally a synth hase a performance mode, in which one can store all the settings of the complete synthesizer. All Clavia synths, accept the NM Classic, have this feature... You have to upload all the Patches yourself by hand. Maybe there is a tool somewhere I don't know about?
Wout
cappy2112
PostPosted: Tue Nov 06, 2007 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
You have to upload all the Patchesw yourself by hand. Maybe there is a tool somewhere I don't know about?
Wout
There is a sysex command that lets you send Patches to Each slot (one at a time). This can be easily done with Midiox et al..
But "storing" them so they are loaded on the next power up- looks like it has to be done the way Jez described.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Nov 06, 2007 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
In a way I was thinking about a computer tool which makes it possible to load more Patches to more slots at once. One to four Patches just place in a tool and by one push on a button they are all loaded; the same procedure for the next Patches. A kind of extern Performance mode. The feature you described is already in the Editor, because he asked you to which Slot you want to upload the Patch.
Wout
cappy2112
PostPosted: Tue Nov 06, 2007 5:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wout
Once the four patches are loaded in 4 slots, you still need to use the editor to save them in the synth. This is tedious- almost not worth the effort (or is it?).
Clavia didn't give us much capabilities with G2 sysex implementation, compared to the Waldorf microwave.
This has an incredibly powerful sysex implementation, and an extremely-well documented one at that.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Nov 07, 2007 2:44 am    Post subject: Reply with quote  Mark this post and the followings unread
You can also use that red button on the synth, can't you? Wink
To the G2 such a procedure isn't important, because the G2 has a Performance mode. A Performance can be just a single Patch. Performance mode can be used to organize the synth related to the songs you need to play. The Classic has no Performance mode, so on stage it's always a lot of trouble getting the synth prepared for the next song. Clavia made the best Performance mode on the NordLead3.
Wout
cappy2112
PostPosted: Wed Nov 07, 2007 10:04 am    Post subject: Reply with quote  Mark this post and the followings unread
[quote="Wout Blommers]You can also use that red button on the synth, can't you? Wink[/quote]
If you have the KB version, yes.
Wout- you know I'm a geek, and as such we geeks lust after good sysex.
(sometimes it's more important than good St**pwafels)
[/quote]
Hello
PostPosted: Fri Nov 16, 2007 9:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for all of the replies. Would be nice if clavia built a G2 with some pots and buttons on it :-> Shocked
Best Wishes
doug Theriault
