Joined: Apr 03, 2004 Posts: 24423 Location: The Netherlands, Enschede
Audio files: 297
Posted: Sat Nov 24, 2007 8:32 am Post subject:
I was looking at it and wondered why I had never seen that scene in the movie
Very good clone ! _________________ Jan
norman phay
Joined: Jun 29, 2007 Posts: 176 Location: North-East England
Posted: Sat Nov 24, 2007 11:08 am Post subject:
mono-poly wrote: | My Wiard Klee slider version.
Need to do another 2 in different formats. |
WOW that looks awesome, Denis. You wouldn't be into making an extra one up, by any chance, would you? |
Scott Stites
Audio files: 96
Posted: Sat Nov 24, 2007 11:26 am Post subject:
Looks like the HAL9000 was hitting the old brewskies there.
Great panel there, Peter.
And Dennis - wow - a Wiard panel! ...oh, man..... _________________ My Site |
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Sat Nov 24, 2007 11:53 am Post subject:
Norman Phay wrote: | mono-poly wrote: | My Wiard Klee slider version.
Norman if Grant agrees that you can have a panel.
Then i would be happy to share the panel design with you.
I can't just share stuff with his graphics without his permision.
But if he agrees you could have a panel like this to. |
Rykhaard
Posted: Sat Nov 24, 2007 12:59 pm Post subject:
v-un-v wrote: | Rykhaard wrote: |
(STILL trying to find paddle switches from that era. ) |
hey Ryk, have you tried any car breakers? Old 70's bangers have those switches  |
Whuuuuuu? Hmmm. That might be an idea. Still though - looking for MANY. (Plans for, 3 x MFOS Sequencers as drum controllers. That's 48 switches minimum, required there.)
I'd at first thought salvaging from an old Altair / Imsai / etc., but - if I were lucky enough to FIND one of those, I'd have it up and running and installed in my modular! lol |
Adam-V
TheAncientOne
Joined: Dec 26, 2006 Posts: 144 Location: United Kingdom
Scott Stites
Audio files: 96
Posted: Sun Nov 25, 2007 12:22 pm Post subject:
Saaaweeet!
For me, that's the ultimate switch. C&K 7211s, are actually DPDT ON-ON-ON switches. Arguably one of the most versatile toggle switches in the world.
Gate Bus 2 could have been made a physical rather than a logical gate bus using these. I avoided that, because new ones ain't inexpensive.
Cheerio,
TheAncientOne
Posted: Sun Nov 25, 2007 12:44 pm Post subject:
Scott Stites wrote: | Saaaweeet!
Scott |
Absolutely right - there was a whole batch of C&K's that came from the same scrap source about 10 years ago, I never actually checked the paddle switches, and all the others were on-off-on. They'll still do the job, if Rykhaard is up for all the cutting out - the one reason I've never used them - they seemed too good to thow away on some small project, and a lot of work for a decent panel. They were originally mounted in a big slot with a gap between, probably just to get the rig working. British Aerospace, or British Nuclear Fuels Ltd, (I forget which).
Amongst some other scrap is the attached ...... must find a space for it on a synth panel one day. A very solid reliable pair of switches.....
Mike
Description: |
And what does this one do..... |
Filesize: |
44.22 KB |
Viewed: |
61646 Time(s) |
_________________ Mike |
Posted: Sun Nov 25, 2007 2:24 pm Post subject:
TheProf wrote: | They were originally mounted in a big slot with a gap between, probably just to get the rig working. British Aerospace, or British Nuclear Fuels Ltd, (I forget which).
BNFL? If they are ex-nuke, then you may have the added advantage of them, ahem.... glowing in the dark!
Awesome!  _________________ ACHTUNG!
Adam-V
norman phay
Posted: Mon Nov 26, 2007 4:25 am Post subject:
mono-poly wrote: | Norman Phay wrote: | mono-poly wrote: | My Wiard Klee slider version.
Should I email Grant about this, then? Loads of thanks, man. |
Posted: Mon Nov 26, 2007 1:16 pm Post subject:
Uncle K...nice! (nice to see you back, btw)
Are those labels across the sliders related to specific output values? ie- notes, etc? |
Posted: Mon Nov 26, 2007 3:18 pm Post subject:
I just put heavier lines at the 1/2 and 1/4 travel points, and slightly lighter lines at the 1/3 and 1/6 travel points. I thought that they might be handy and yet unspecific reference points. For example, when you want to quickly set No.14 to the same value as No.3.
As it turned out, when I did the Lazertran and saw the result on the panel, I thought that it just looked really good, and was typical of the kind of graphics you get behind a series of controls like that on commercial equipment. It will look even better when I finally track down some knobs for my sliders.
BTW The actual voltage level (and therefore note value) changes depending on where I have the Max Voltage set. So it really is just a way of dividing up the travel. _________________ What makes a space ours, is what we put there, and what we do there. |
loopcycle
Posted: Mon Nov 26, 2007 5:52 pm Post subject:
krunkus, i really like how you used a sub-panel to mount your sliders. and that woodgrain really looks hot too.
do you mind posting your photos of the subpanel again? id like to see how you mounted it to the frontpanel and the distance between the two, etc. |
Posted: Tue Nov 27, 2007 2:17 am Post subject:
loopcycle wrote: | krunkus, i really like how you used a sub-panel to mount your sliders. |
oh yeah, i wished i did it this way. it's worth the effort! _________________
Tech Buddy at Random*Source |
Posted: Tue Nov 27, 2007 2:22 am Post subject:
fonik wrote: | loopcycle wrote: | krunkus, i really like how you used a sub-panel to mount your sliders. |
oh yeah, i wished i did it this way. it's worth the effort! |
ala MS20?!  _________________ ACHTUNG!
Posted: Tue Nov 27, 2007 2:24 am Post subject:
sliders no a ms20  _________________
Rykhaard
Posted: Tue Nov 27, 2007 7:37 am Post subject:
fonik wrote: | sliders no a ms20  |
No - but it's the same way that Korg had constructed theirs. I found that when I was hauling mine apart, to service it.  |
factus10
Joined: Jun 20, 2007 Posts: 158 Location: Buffalo, NY
Posted: Tue Nov 27, 2007 8:13 am Post subject:
fonik,
was your panel done by shaeffer? would you mind uploading the fpe file if so?
thanks!
david |
