GM Voice/MIDI Utilities
Page 2 of 2 [27 Posts]
Goto page: Previous 1, 2
Thomas Henry
PostPosted: Tue Feb 05, 2008 10:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Scott Stites wrote:
I suppose the same applies to SFZ? If I should happen to be using the internal soundcard synth, even more so.
Absolutely! For my regular setup, I have one profile for the GM-Voice and another for sfz. When I boot up my system, I run two instances of MIDI-Ox, load in the respective profiles and away I go, in less than a minute.
So far, I've been using sfz to do the drums and percussion and the GM-Voice to do everything else. I've got voices coming out of my...well, you know...now.
So, again for all you GM-Voice builders, MIDI-Ox is the desired control element you'll use and use again. And the same thing applies to sfz users (which is basically just a software version of the GM-Voice.
Thomas Henry
PostPosted: Wed Feb 06, 2008 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay dudes I'm sold, well, at least on Midi-yoke I am.
Now go and have a look at the MPS thread and my new front panel. Very Happy
